1978 - 1996 Big Bronco
turning AC into air compressor
Old Feb 28, 2005 | 08:42 AM
LilDuke's Avatar
LilDuke
Has anyone done this before? I don't use the ac in my 87, i'd rather take the top off. This seems much more useful. The only thing I would change is the wiring to ac cluch. I'd put in a pressure relay to turn off, and a check valve to keep air in.
On Board Air
Also, A couple of useful websites I found while surfing last night.
Vehicle Recovery
1983 Ford Bronco pictures, pics, videos, and sounds | SuperMotors
Later,
Dave
Old Feb 28, 2005 | 01:55 PM
LilDuke's Avatar
LilDuke
Ok, why are all my links going to Library of Congress?
Old Feb 28, 2005 | 02:48 PM
Outlawwv's Avatar
Outlawwv
i did it once on a chevy van -- the compressor didnt make a whole lot of pressure so i got a valve that would let 3 lbs ( i think) through and would hold back 150 lbs (i think its been awhile) with a pop off valve on the tank. also had another truck that just had afitting on compressor to hook air line to and a switch to turn it on when needed
Old Feb 28, 2005 | 02:52 PM
LilDuke's Avatar
LilDuke
Do they make a compressor that bolts into it's place that I could do the same thing?
I want to get a bit air bag that I can inflate if I get stuck somewhere by myself.
Old Feb 28, 2005 | 02:56 PM
Outlawwv's Avatar
Outlawwv
i used the a/c compressor that was on the van
Old Feb 28, 2005 | 03:01 PM
LilDuke's Avatar
LilDuke
How many PSI does it put out?
http://wt4x4.net/tech/onboardair.htm
On Board Air
brian.taylor
46
Nov 21, 2019 08:38 PM
Ken00
1983 - 2012 Ranger & B-Series
Mar 27, 2014 04:16 PM
96_4wdr
Aerostar
Feb 13, 2008 09:23 PM
bigun72
General Automotive Discussion
47
Aug 17, 2007 07:24 AM
cleatus12r
Offroad & 4x4
May 26, 2005 11:35 PM
