92 ranger timing
Old Feb 27, 2005 | 10:47 PM
custom69's Avatar
custom69
Question 92 ranger timing
Hi, i was wondering how to change the timing on my dad's 92 ranger it has the 4 cyl
Old Feb 27, 2005 | 11:52 PM
el conquistador's Avatar
el conquistador
the timing is not adjustable. what is wrong with the truck?
Old Feb 28, 2005 | 04:47 PM
custom69's Avatar
custom69
ok, when we checked the timing it was 15 degrees advanced and i live in colorado where it should be around 10 degrees advance, The problem is that the truck is very under power i know it is a 4cyl, but it is horribly underpowered and i do not think it is running like it should
Old Feb 28, 2005 | 05:42 PM
Ken00's Avatar
Ken00
Have you checked for codes, tested the fuel pressure, checked the intake vacuum, and done a complete tune up.
Old Feb 28, 2005 | 08:31 PM
Wanted's Avatar
Wanted
You do know you cant just hook up a timing light and expect it to be right.
The 92's you have to pull out a fuse type thing to put it in the base mode, where it should be 10*
What is it doing? They are underpowered, 100hp isnt going to be quick.
Old Mar 1, 2005 | 05:17 PM
custom69's Avatar
custom69
We did pull out the fuse and we still came out 15 degrees advance
Old Mar 1, 2005 | 05:21 PM
custom69's Avatar
custom69
This truck has been in the family for a while, we know how much power its supposed to have or how much it originaly had, and it has been decreasing in power.
Old Mar 1, 2005 | 08:08 PM
Ken00's Avatar
Ken00
You could also do a compression test.
Old Mar 2, 2005 | 12:38 AM
el conquistador
where is this fuse at? we are talking about a DIS 4 cyl. right?
Old Mar 2, 2005 | 06:59 AM
Wanted's Avatar
Wanted
It isnt a fuse, I cant think of the real name off of my head. It is like a fuse, there is a plastc silver box by the PS Pump which has some red wires coming out, which are connected to one another by this grey fuse thing.
Old Mar 2, 2005 | 06:47 PM
custom69's Avatar
custom69
Ya, thats what we pulled, it is a 3.4l 4cyl
Old Mar 2, 2005 | 07:01 PM
el conquistador
you might want to check the displacement on that motor if it is stock. do you mean
2.3 L?
Old Mar 5, 2005 | 12:15 AM
el conquistador
is it right next to the DIS module?
Old Mar 5, 2005 | 01:59 PM
Wanted's Avatar
Wanted
Look around your power steering pump.
