transmission recall question
Old Feb 27, 2005 | 10:29 PM
g tinsley's Avatar
g tinsley
How do you tell what job no your torkshift tranny was built.I have a 2005 transmission build date of 12-08-04 but do not know how to tell the job no.Thanks for your help
Old Feb 27, 2005 | 11:52 PM
Hayapower!'s Avatar
Hayapower!
04B24
Certain 2004 Model Year F-250/350/450/550 Super Duty, Econoline, and Excursion vehicles equipped with a 5R110 TorqShift transmission built from March 8, 2004 through June 24, 2004. Affected vehicles are identified in OASIS.
Some 2004 MY Excursion, Super Duty and Econoline vehicles equipped with a 5R110 TorqShift transmission may have low/reverse gear set pinion shaft(s) that may walk out, causing metallic particle contamination. If this condition were to occur, it may lead to harsh/slipping shifts and/or harsh/delayed forward/reverse engagements. If these symptoms are ignored, this could eventually lead to a transmission failure.
05B27
Certain 2005 Model Year F-Super Duty Vehicles Equipped with a 5R110 TorqShift Transmission and Snow Plow Prep Package
Transmission Low/Reverse Snap Ring Replacement
Have it checked.. But, usually the transmissions are 'built as needed' and there isn't a huge stock pile 'or' months of tranny units laying around waiting for an engine mate.. My 05 was a Oct. build and was clear of the recall/s.. Note the latter recall 05B27 is for snow pushers with a PTO provision if it applies..
Hope this helps..............HP................
Tjhunter-jeepman
6.7L Power Stroke Diesel
21
Mar 6, 2011 02:00 AM
lee3
6.4L Power Stroke Diesel
Nov 29, 2007 10:51 PM
95starnTN
Aerostar
Dec 21, 2004 01:07 AM
Mike W
40
Jan 7, 2004 11:31 PM
Mike W
26
Oct 20, 2003 07:52 PM
