Hey guys, My 86 F-250 XLT with a 460 (recently purchased long block) has started to smoke,get this,only when making left hand turns.All other times it seems to be normal,except when making a left hand turn. If I'm on the gas thru the turn it's like I set off a smoke bomb. Any suggestions as to what this might be? My warranty has recently expired,so I'm on my own now. Could it be the "turkey" pan has lost it's seal and is allowing oil into the intake? Please help. Thanks again.
A carb problem. Perhaps the float doesn't work right during sideways g-forces.
A leaking brake master cylinder that has filled your brake booster with brake fluid. A left hand turn would slosh the fluid to the right side of the booster - which is where the vacuum line hooks up. Check if the rear brake fluid reservoir (front brakes) is low.
What color smoke? Yeah, go take a hard left turn and be hang'in out the window lookin backward to see what color smoke so you can tell us all about it
If its bluish white oil smoke, an idea would be bad intake valve stem seals on the left head. A hard left could be keeping the oil from running down the head drain hole, putting more oil around the topside of the intake valves, sucking down into the cylinders. Just an idea, not a for-sure.
ALASKAN, I sure hope your going to tell us what it was when you get it figured out, and not be like a lot of first-time posters that we never hear from again! Thanks
Don't worry,I'll let you know as soon as I find out. I don't understand the power steering theory though. The smoke is definitely engine oil. I'm beginning to think it's in the heads.
I was hoping you'd come back so I could ask about the 'turky pan' . LOL! At first I though it was an aluminum intake manifold, then I started wondering if it's the valley between the cylinder's. Which is it?
I saw this happen once, way back in the sixties. The car, a 60 or 61 Ford (can't remember which) had been over-filled with oil. Could it be that simple?
