voltage regulator problems
Old Feb 27, 2005 | 02:17 PM
K_longshore's Avatar
K_longshore
78 F150 voltage regulator problems
I have only had the truck for six months and have had to replace the
regulator three times . the last time during the last rain here in vegas.
i have made sure it was grounded well but it keeps going bad and draining the battery . Is this a commin problem ???
Old Feb 27, 2005 | 03:07 PM
LxMan1's Avatar
LxMan1
Welcome to the forum. No, this isn't a common problem. It happens occasionally, but not that often. Did you get them all at the same store? Maybe they just got a bad batch of them.
Old Feb 27, 2005 | 07:56 PM
Franklin2's Avatar
Franklin2
The alternator, or the wiring can ruin the regulator. If the "F" wire is rubbing metal somewhere, or the field in the alternator is intermittently shorting to ground inside the case, it will burn up the regulator.
raye321
Oct 25, 2017 07:41 AM
jrappl
Mar 28, 2017 07:54 AM
packagerjr
Sep 23, 2016 06:04 AM
forestgreen
22
Jul 13, 2015 05:52 PM
77429highboy
Nov 10, 2011 08:40 AM
