turbo leak
Old Feb 27, 2005 | 11:17 AM
kingranchf350's Avatar
kingranchf350
turbo leak
hey guys,
i have a problem on my 2000 F350 7.3L psd, when the truck gets driven for the first 5 or so minutes after cold start up, you can hear what i think sounds like turbo blow by up at the firewall,as soon as the engine warms up its gone...
if it were the waste gate it would be coninuous--- right?
has anybody had this problem?
i checked all the clamps and they seemed tight...
the truck is quite a ways from a ford dealership, so if anybody has any suggestions i would love to hear..
thanks
Old Feb 27, 2005 | 11:37 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Is it cold out? It sounds like it's probably the exhaust backpressure valve doing it's thing.
Old Feb 27, 2005 | 04:15 PM
kingranchf350
its around frezzing... when your accelerating you can feel the engine bogging down when the noise starts, it feels like the boost is just leaking out somewhere...
i have a few of these F 350 and no other truck has done this...its quite loud
Old Feb 27, 2005 | 07:21 PM
slc10844's Avatar
slc10844
You might want to check the ebv sensor and tube for being clogged.
Old Feb 27, 2005 | 08:07 PM
firebiz16's Avatar
firebiz16
My 1999 PSD is doing the exact same thing, when the motor warms up it stops. I was also told to check or change the ebv valve also, DUH, can some explain where this might be located. Or what it looks like?
Thanks,
Chris
Old Feb 27, 2005 | 09:56 PM
cookie88's Avatar
cookie88
FTE Emeritus
That almost surely the EBV. The electrical connector for it is dwon at the base of the turbo. Won't take but a minute to unplg it and take it for a test drive to see if it's still doing it.
It can engage whle the vehicle is in operation if the right conditions are met, a quick stab of the throttle should disable it.
Old Feb 27, 2005 | 10:30 PM
kingranchf350
what does EBV stand for......
i had a real quick look and couldn't find the connector.... where should i be looking again?
Old Feb 28, 2005 | 03:23 PM
slc10844's Avatar
slc10844
Exhaust Backpressure Valve. You can unplug the sensor on the front of the engine and it will go to the default mode. The valve will remain open. The sensor is in front of the high pressure pump and inboard of the A/C compressor.
DieselVol
Jan 31, 2013 08:54 PM
blackhullpirate
Oct 7, 2009 01:19 AM
Jakesrodshop
Apr 15, 2008 05:37 PM
LANCE KOBUSCH
Sep 23, 2006 12:43 AM
odie780
Apr 6, 2002 11:38 AM
