memory keep alive code
Old Feb 27, 2005 | 08:05 AM
mpbpulaski's Avatar
mpbpulaski
I am keep getting a memory keep alive code with my '02 F350. Anyone have any ideas as to the cause? What will this affect on my truck?
Old Feb 27, 2005 | 10:04 AM
CAT_man_963's Avatar
CAT_man_963
That would be the tuner in your Sig that causes that code I believe. Any time you mess with the PCM with a programmer (mine did when I had my SCMT) or even if you disconnect the batteries to work on the truck - you get that code. As long as your truck is running fine - I wouldn't even worry about it. I'm pretty sure that using a tuner to clear the dtc codes might even set that code - at least my scmt did that. It takes time for the pcm to clear the code on it's own - but if you regularly use the tuner to change between different tunes, then you might always have that code.
stroke-of-luck00
Oct 22, 2007 07:34 PM
foxracer800
Sep 26, 2007 04:20 PM
glmf 1
Oct 23, 2006 05:58 PM
BUFFSTROKER
Jun 18, 2004 08:59 AM
coplin
Apr 15, 2004 11:55 PM
