4 speed for a C6
Old Sep 27, 2001 | 06:34 PM
fossil's Avatar
fossil
4 speed for a C6
I'm getting a C6 plus transfer case for my 86 F-150 4x4. I have a 4 speed now. What kind of swap problems will I encounter.
Thanks for your input,
Harley
Old Sep 27, 2001 | 09:40 PM
Fordtruxrok's Avatar
Fordtruxrok
4 speed for a C6
you'll hazve to: lose the clutch for a flexplate & torque converter, get an auto shifter, get an auto linkage, maybe change crossmember, different driveshaft, might have to change your throttle linkage for a tv cable connection, install a trans cooler, install lines for trans cooler, buy 13 qts of trans fluid, run a vacuum line for modulator valve, change front driveshaft, and possibly have to change the 4wd shift linkage.
Did I miss anything??
John
Old Sep 27, 2001 | 11:08 PM
restorit's Avatar
restorit
4 speed for a C6
Maybe one detail. Unsure of your engine, but if it's EFI (i.e. the 302) you may need a new computer (?) Didn't these make a distinction between a standard trans and an automatic? Also, you'll need to figure out something new to do with your left foot and your right hand ! Just kidding, though getting into the same body-styled auto after driving my stick drives me nuts for the first several hundred miles, especially when I stomp the floor pan looking for the clutch when I come to a stop! Good luck!
Old Sep 27, 2001 | 11:46 PM
slimersoup's Avatar
slimersoup
4 speed for a C6
What's the difference in front driveshafts between sticks and auto's? A Bronc with a C6/NP208 uses the same one as a T-18/BW1356. I assumed it would be the same for all 1980-1996 fullsize trucks and Bronc's with a given front axle.
Old Sep 28, 2001 | 07:13 AM
fossil's Avatar
fossil
4 speed for a C6
Just to up date my origanal posting,
I have a 1986 F-150 4x4
Built 300 HP 300 i6
My transfer case broke in half so I need to replace it. I wanted to build a c6 up and install it anyway. So now that the case is toast I might as well change everything.
Thanks for all your help guys,
Harley
Old Sep 28, 2001 | 07:56 AM
lanero's Avatar
lanero
4 speed for a C6
[font size="1" color="#FF0000"]LAST EDITED ON 28-Sep-01 AT 08:57 AM (EST)[/font][p]
The difference would be the length of the shaft. I went from a M5OD 5-speed to a NP435 and there was a 3 inch difference in length. Needless to say, the rear shaft had to be re-tubed 3 inches longer and the front needs to be cut 3 inches.
I hope this answers your question. ;-)
Roger Lane
Test Analyst
Sr. Automated Test Engineer
IBP, Inc.
Old Oct 1, 2001 | 02:01 AM
slimersoup's Avatar
slimersoup
4 speed for a C6
Yeah that explains it. Thanks.
Old Oct 1, 2001 | 05:00 AM
Fordtruxrok
4 speed for a C6
There won't be any computer problems since the c-6, and your original 4spd aren't computer controlled.
John
Old Oct 1, 2001 | 05:05 AM
Fordtruxrok
4 speed for a C6
1971f1002wd
26
Jan 1, 2017 06:08 PM
peakster
Jun 11, 2016 04:18 PM
peakster
Jun 11, 2016 12:22 AM
rews2
Mar 5, 2016 08:56 AM
blk450er
39
Feb 16, 2016 09:19 PM
