Girly Powered Effies.
Vern
That does sound like a crazy little engine. I'll be hanging around with the crowd that has less than 8 or 10 grand invested in their motor though. Only half the power you and Dick are talking about would be more than sufficient for most of us. Still. it would be neat to see a 500HP 302, any way you do it.
They have been listening to the "Users" and have started to make changes to components that will make ALL current engines more compatable to use in other vehicles, plus supplying the Goodies necessary to boost the performance.
Some of the major complaints being addressed are - Plug and Play Wiring Harnesses. GM had one Plug through the Firewall for the major components Ford had 5 or more.. Fords small block had a water pump that made it longer than a GM big block. It will take some time but the "Put a Ford in your Ford" is more than an ad campaign
According to a build computer from a race team, with a mild cam and the heads reworked with big valves, I have 315 and 389tq, so the computer says. Do you have to ever crank an engine to brag about power? That may happen in March as the mini/major resto should be complete.
Purple
Your on pink slip for pink slip! Bring yours to Knoxville, I'm tired of being beat up over a 'girly motor'
, I'll show you.......Now just one addition to the great race....distance will be one tank full of gas. Rules...no aux tanks or fuel tankers allowed.
Jet Jock
"I drive a 'girly'
302 because, when I want to go fast, I go to work"
Absolutely not Bill. You're word is good here. Purple has to prove you're lying, and all the "girls" here will come to your defense.
So we'll just round your numbers up to an even 400HP/450# torque and call it good. That'll kill a stock big block Lincoln motor. And that's all we need for now. You're the man Bill.
Seriously though, those torque numbers on a non-stroked 302 in a streetable and naturally-aspirated package would require you to really get it dialed in really-really right. You'd need a real good set of heads. I'm not even sure FMS Aluminum GT-40 Y303 aluminums would get you there without working them over. AFRs could do it though.
The euphoric power seems to be a stroker. The stroke to bore ratios can be optimized, and the torque just comes without even trying. I'd like to see some of these modern tactics and parts available for a Y-block. The Y-guys are seriously handicapped by forty+ year old heads and intakes.
Where the power happens is what is so critical to me. I've got it wrong a few times. Big horsepower means nothing from a practical standpoint, if you have no torque until the engine hits 3500RPMs, but you know that already. Fear of repeating that mistake is what caused me to underbuild my current motor. And I'm not about to over-react by buying what some kids friend bought on a Mustang forum. There's a lot of unpractical "wisdom" being offered up on the net. Tough to sort through it all.
Dick
That is GREAT news. It can't happen soon enough. Ford really screwed themselves right out of the aftermarket for decades with their tactics. Henry would NOT have been impressed.
Well Ford got one thing just like the aftermarket. We are in the process of installing a 97 5.0L in a 29 ford tudor. My friend want's it to have a mech fuel pump and carb (less wiring) so we went to the local ford dealer and bought a new short water pump for "V" belts and the matching 2 grove pulley set. Got it home and just like the aftermarket the pulley holes are just off enough that only 2 bolts will screw in so we get to modify the pulleys.
It sure would be nice if the quality was better but just like everything that he has bought for this hot rod you get to spend twice as much time fixing as you do installing.
But it will have a Ford powertrain come h*ll or high water!
Chuck
Merc- I feel your pain on the pulleys. I went through the same thing on my engine. Amazingly the previous owner used GM pulleys and redrilled the holes to fit the engine (mickey mouse to say the least). I couldn't find Ford pulley that would line up with the alternator or clear the water pump. I finally found a Pulley from a GM product (don't tell anyone) where the bolt holes lined up and the V belt aligned with the alternator, and it was chromed to boot. If everything went together perfectly, we wouldn't have all this fun and my refridgerator would still be full of beverages. (smile)
Lower,
I completely agree. I want that magic spot in between. I didn't realize it was really an option with a 302. Always assumed 300HP with decent torque was not a reasonable goal for the street. Seems that it is now days. Gotta agree on the 500-700HP stuff. You're gonna need scheduled ring and bearing changes. That's not for me. There's no way that is going to come in a package you can drive up and down the interstate without a care. I couldn't afford it even if it was. Weight savings is one of the biggest reasons I desire to stay 302 blocked.
I was hopeful I could pull a few 5.0 tuning experience members out of the woodwork with this thread. I know PJS55 (John) is very interested in the subject too. I haven't paid any attention to the EFI threads over the years.
FF56
As for as the posturing, it's got some history here. You see Jet Jock and I are the smallblock "good guys". We didn't start this girly 302 thing. Purple55 is the evil Bigblock man. He's really mean to us but we enjoy it.
And you got to remember a 351C is pretty easy to be satisfied with. The torque is factory installed. We don't really have that with a carbed 302. Almost all the old smallblock heads are really pathetic. Exceptions are few.
Inches count and unless someone wants to refute the laws of physics it aint gonna change.
When you get to the 351W and stroker versions you are already in the realm of the 352/390 FE and those aint little blocks. Ive a 351W in my 12' dually E350 box truck and that moves pretty decent even overloaded. Going with a Weiand Stealth/Edelbrock 1406 and long headers into a single big pipe as soon as I can get all the parts together. Just need a bit more pull on long hills when Im way over the weight limit. Ford Performance and Edelbrock also have much better heads available than the 86's Im using, but Im not that desperate to spend that much money. Id go 460 first.
Dont discount a 460. My buddy has a 96 F450 ?? 16' box truck and with some aftermarket stuff and tuning he gets 16-18 mpg with a moderate load on the OD AT. And that thing has got some serious pull off the line. He can tow my dual axle car trailer with one of his 60's MOPAR Hemis on top and not even feel it.
