Installing brake controller?????
Old Feb 24, 2005 | 09:56 PM
CC'sDad's Avatar
CC'sDad
I'm installing a brake controller on my 99 f-350 and from what I understand there is a plug under the dash. My problem is, where can I find an adapter that plugs into it? Or does someone have a wiring diagram that I can just splice it in from. I would prefer to have the adapter, but I've been known to hack on stuff befor and I'll do it again if I must.
Thanks
Old Feb 24, 2005 | 10:45 PM
wlihntr's Avatar
wlihntr
most brake controller manufactures sell a plug that will plug into their controller and plug into the factory plug under the dash, if you cant get that then ford sells a plug with open wires that you can splice your controller wires into.
ford part #F81B-14A348-A (jumper harness)
FordPowerStroke's Avatar
FordPowerStroke
I bought a brake controller for my 97 and I just plugged it in after finding the plug under the dash. It took about 1 minute to plug it in and about 2 minutes to mount the controller. If you haven't found a compatible plug-and-play controller keep looking.
Old Feb 25, 2005 | 05:26 AM
rockyrider's Avatar
rockyrider
Check here. You'll have to copy and paste.
http://www.etrailer.com/Merchant2/me...tegory_Code=BC
Old Feb 25, 2005 | 06:33 AM
bilder12's Avatar
bilder12
I found my plug adapter at ford for 8.50 US. The controller should have the wiring schematic with it.
Dlebl1
All Things Towing
Aug 5, 2013 04:33 PM
old farmer
Feb 4, 2009 10:01 AM
dogzpaws
All Things Towing
Aug 31, 2007 11:02 PM
nowakr
Sep 20, 2006 04:31 PM
