super heater or standard?
Old Feb 24, 2005 | 06:17 PM
oldfordtrucksrule's Avatar
oldfordtrucksrule
i have a 1983 f100 with ac. wondering how to tell if i have a standard or super heater core. anybody know?
Old Feb 24, 2005 | 09:40 PM
Beast12's Avatar
Beast12
If you have AC you will have the super heater core. I am pretty sure.
-Matt
Old Feb 25, 2005 | 02:42 PM
Grandpa's1983's Avatar
Grandpa's1983
Hello, the hi-output heater core is 7½ inches wide 2¼ inches c/c of tubes
the standard heater core is 6 inches wide 2½ inches c/c of tubes
c/c I think means center to center of tubes.
Old Feb 25, 2005 | 03:00 PM
mstarr's Avatar
mstarr
I checked my LMC catalog and it only shows the "hi-output" under the "without A/C" parts list. The "with A/C" shows a totally different part #. I am guessing that the standard and Hi-output can't be much different since they are the same price, but the picture doesn't show.
Old Feb 26, 2005 | 07:42 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards.
Old Feb 26, 2005 | 08:22 AM
Boss50's Avatar
Boss50
I have no A/C and it says Hi-Output on my heater box.
Old Feb 26, 2005 | 12:10 PM
mstarr's Avatar
mstarr
Now that I think about it, My truck heater box says "hi-output" on the box too, but mine DOES have A/C. Strange.....
Old Feb 26, 2005 | 04:03 PM
howler's Avatar
howler
in the base trucks you could get either heater core,... hi output or the little core
Old Feb 26, 2005 | 10:12 PM
mustange70's Avatar
mustange70
If you have high output on the heater box or the heater controls, you have the "super Heater"
Old Feb 27, 2005 | 12:52 PM
bremen242's Avatar
bremen242
can you switch to "super heater"? my truck doesn't blow that much heater since I have no insulation on the floor..
Old Feb 27, 2005 | 04:02 PM
mustange70's Avatar
mustange70
You can but you have to change the entire heater assembly as the heater cores are larger on the "super Heaters" and so other minor things to accomdate it, or you can upgrade to a 195 degree t-stat (which i have, but my heater is a low-output one, but the high t-stat will cook me out of the truck on even the coldest of days).
Old Nov 10, 2005 | 05:21 PM
oldfordtrucksrule
the standard heater core is 6 inches wide finally got around to changing it today. my core measures approx 7 by 8 inches. the case doesnt say super heat. local az has only the stock non super core, they measure it and tell me its 7 by 8 inches. so i buy it and its exact match. so the stock core size is not 6 inches wide but 7 1/2.
Old Nov 10, 2005 | 08:23 PM
Grandpa's1983
That could be, I guess it is time to start fixing those heater cores that have been bypassed since spring, I was going by a ford parts catalog but they arent perfect especially on some of the older stuff. thanks for the info, you really pulled a thread out of the spider webs here!
Old Nov 10, 2005 | 08:27 PM
82F100SWB's Avatar
82F100SWB
The High Output heater setup is a direct bolt on if you have a standard heater. Adding a Comfort Vent heater(has dash vents and vacuum controls like an A/C unit,) or A/C is not a bolt on swap and requires wiring changes, and cutting new holes in the firewall, along with changing the entire dash... I just did it when I planted my 81 cab on an 86 diesel chassis.....
6t6merc
Jan 30, 2023 01:36 PM
bobcf
Jan 15, 2015 06:40 PM
RichardBlack
Oct 21, 2011 04:12 AM
towtruck1
Dec 7, 2006 10:59 PM
Quinny
1983 - 2012 Ranger & B-Series
Nov 2, 2005 08:42 AM
