shuddering powerstroke
Old Feb 23, 2005 | 04:34 PM
OldYoungDad's Avatar
OldYoungDad
Need some help. I have a 1996 powerstroke that misses so badly the truck shudders under acceleration. Truck has a new fuel filter. Verified all injectors are receiving a fire command. Thoughts?
Old Feb 23, 2005 | 04:41 PM
Cuda_jim's Avatar
Cuda_jim
Maybe the trans or converter?? Does the engine rev up OK when not in gear?
Old Feb 23, 2005 | 05:46 PM
F-250 diesel's Avatar
F-250 diesel
if its missing, it could be the cam position secsor (CPS)
Old Feb 23, 2005 | 05:49 PM
ltfox's Avatar
ltfox
more info, 5spd or auto, also little bit more about the shudder. Does it only do it going down the road.
Old Feb 23, 2005 | 07:05 PM
OldYoungDad
truck has a manuel trans. Miss is noticeable under no load. Shudder diminishes at 2500 rpm under load. truck is way down on power/acceleration. Thought about the daul mass flywheel but not sure how to verify.
Old Feb 23, 2005 | 08:30 PM
F-250 diesel
sounds like a cps to me
Old Feb 23, 2005 | 09:05 PM
ltfox's Avatar
ltfox
Cam sensor is a possibility. Are you getting a CEL(check engine light). Have the codes pulled see what secrets your computer has. I'd would lean away from it being the DMF where your low on power. Another possibility is a burnt valve cover harness.
Old Feb 23, 2005 | 10:02 PM
OldYoungDad
Not getting a CEL. I'm starting to lean to the harness however. For a minute I thought the Banks chip was haywire. Pulled it but problem persists. Will try to get my hands on a code reader tomorrow. If I'm lucky I'll get a reader that allows turning off injector commands one cylinder at a time.
Old Feb 23, 2005 | 10:47 PM
ltfox's Avatar
ltfox
You may try to disconnect the valve cover harnesses with the engine running, one at a time. That will kill two cylinders at a time though. Just see which connector make the least difference in how the truck runs.
Old Feb 23, 2005 | 11:10 PM
OldYoungDad
Sometimes simplistic brute force is best. I'll give it a try if the code reader doesn't yield some secrets.
mvedepo
2009 - 2014 F150
46
Dec 17, 2015 05:48 AM
powerstroker100
21
Sep 7, 2010 01:01 AM
EXPLORER GUY
17
Jun 27, 2008 06:39 PM
Kuskoal
Apr 26, 2008 07:23 PM
Red03XLT
2004 - 2008 F150
Sep 21, 2005 04:53 PM
