Dissassembled My 400 Partially To Replace Head, Intake, Oil Pan, And Valve Cover Gaskets, And To Clean Out The Funk.
But....when Rotating The Engine On The Stand, I Forgot My Pushrods, And They Fell Out!
Now They Are All Mixed Up, So What Problem Will I Run Into When Reinstalling Them?
Or Does It Really Matter?
The Engine Has 77,000 Miles On It.
Some may have wear patterns set up. I would replace them all if you are going to use the engine for a long period. If you just need to fix it long enough to run for a little while just pop them back in.
I have pulled engines apart where there was almost 1/8" difference in length on some of the pushrods due to wear. They wear in odd shapes even if only by a few thousandths of an inch but then so do the mating surfaces. Putting two odd shapes together is worse than putting one good surface next to a misshapen one.
and to add to Eric's comment new stock pushrods really don't cost that much expecially when you consider maybe replacing lifters, and rockers. I have done it on occasion in an emergancy, or in the case were there was very little mileage on the engine.
