4x4 Launch
Old Feb 23, 2005 | 11:27 PM
Brian460's Avatar
Brian460
Originally Posted by smokin_6.0
half of a second man this truck must be faster than i thought since that would get it in the 13's its kinda hard to believe but i will probably try it
If the truck is stock with the SCMT I would say around 14 flat.
Old Feb 23, 2005 | 11:32 PM
Brian460's Avatar
Brian460
Originally Posted by SMiller
I would think with more power you would better off in second gear, first comes and goes fast with just a stock truck, I would think with 100 more horse power you could just go second and get a little faster time, you would have a lot more boost taking off anyways, anyone ever do this?
No matter what gear you are in at a dead stop foot on brake, you will see the same boost. Gear selection will have no affect on t/c stall. If using an auto. always use first the harder you can lauch and get moving the better the 60ft. time will be.
Old Feb 23, 2005 | 11:33 PM
Daryl Hunter's Avatar
Daryl Hunter
I ran a pair of 14.33 s 1/4 mile runs with my SCMT on High Performance tune. The truck ran 16.0 s stock.
Daryl
Old Feb 24, 2005 | 10:21 AM
texan2004's Avatar
texan2004
Originally Posted by PSD 60L Fx4
My truck has been in 4x4 for very extended periods of time at both low and high speed, both straight and curvy roads. It has seen numerous passes across Jones
Gap at full throttle, in 4x4, with all 4 tires slipping through the curves. Have been to around 125 or so in 4x4, slowing into turns anywhere from 65-90 and full throttle through the back third of the corner. So far, no damage done, other than a hub that decided to grenade at launch once.
125MPH and 65-90mph through the turns???
Start making your list fellas. We are going to have a parts truck to pick through pretty soon.
Old Feb 24, 2005 | 10:36 AM
jdadamsjr's Avatar
jdadamsjr
TeeHee
Practice makes perfect !
Old Feb 24, 2005 | 10:57 AM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Whats a transfer case after 1 engine and two transmissions?
In all honesty, it has handled the abuse very well. It theortically should have self-destructed a long time ago.
JRussell3176
2009 - 2014 F150
Feb 9, 2017 11:55 AM
036.0stroke
Oct 21, 2016 03:38 AM
DerekShiekhi
Oct 11, 2016 04:15 PM
Krazee Matt
Jun 15, 2016 10:50 AM
magicsac1366
Competition
44
Nov 28, 2015 11:42 PM
