Aerostar Ford Aerostar
70 MPH howling noise
Old Feb 21, 2005 | 06:31 PM
Machman's Avatar
Machman
Hey Guys,
This one has me stumped. 91 3.0 ext 185k. I get a howling noise at around 65-70 mph in drive and overdrive. New tires, brakes and alignment. The van runs good and shifts perfect, it just seems to have a continuous howl coming from around the engine/trans cover at around 65mph and up. I dont have any leaks or slippage. I put on an auxilliary trans cooler and that did clear up the trans puking fluid out the front seal area on long trips. The trans is a rebuilt unit from the previous owner and I replaced the transfilter and fluid just to be sure. It never did this before. It will make this noise when I am under power and almost go away when I let off the gas. It comes in at 65 mph in both drive and overdrive and does not make the sound when I just rev the engine to the corresponding rpm in neutral. I thought it was a tire balance issue ,but that was eliminated when I replaced the tires.
Any suggestions would be a great help...Thanks
Old Feb 21, 2005 | 08:30 PM
93nighthawk's Avatar
93nighthawk
What is the condition of your exhaust, cat, and headers. Just a thought is that howling that you hear is from an exhaust leak. Without hearing it, it is difficult to diagnose.
Old Feb 22, 2005 | 10:04 AM
yendor's Avatar
yendor
machman
Get it up to speed and then put it in neutral and coast down the road at that speed see if the noise stops. If it does not stop I would start to check wheel bearings. Also check rear end for grease level they can make some strange noises.
Old Feb 22, 2005 | 10:58 AM
93AeroEB's Avatar
93AeroEB
Ours howels at any speed - it is because the van is so heavy (but within spec for the tires) - all wheel bearings have been checked &/or replaced. If you have new tires, and know you have good wheel bearings, it might be just the nature of the tires to howel. I know the old Goodyear Aquatreads really howeled if you went 65+. Your other choice is a truck tire - and with the Aerostar's suspension being what it is, I would not recomend it for the sake of your passengers.
Good Luck!
Old Feb 24, 2005 | 06:09 PM
Machman's Avatar
Machman
The cats are good and the muffler and tailpipe are new 2 months ago. I will give the rolling 65 mph check a try.
Old Sep 5, 2005 | 01:30 AM
cldoug11's Avatar
cldoug11
This is a direct quote from alldata.com:
Article No.
96-17-22
08/12/96
^ NOISE - "WHINE/HOWL" FROM REAR AXLE DURING LIGHT THROTTLE AT SPEEDS BETWEEN 56-72 KM/H (35-45 MPH) OR AT HIGHWAY SPEEDS DURING ACCELERATION OR DECELERATION
^ REAR AXLE - "WHINE/HOWL" NOISE DURING LIGHT THROTTLE AT SPEEDS BETWEEN 56-72 KM/H (35-45 MPH) OR AT HIGHWAY SPEEDS DURING ACCELERATION OR DECELERATION
LIGHT TRUCK:
1986-96 AEROSTAR
This TSB article is being republished in its entirety to correct the axle ring gear ratio from 4.00:1 to 4.10:1.
ISSUE:
Some vehicles may exhibit a rear axle "whine" or "howl" noise. This noise may be audible during light throttle at speeds between 56-72 km/h (35-45 mph) or at highway speeds during acceleration or deceleration. This may be due to the ring and pinion gear set.
ACTION:
Select the appropriate ring and pinion set from the Parts Block listed below and replace the ring and pinion set.
Old Sep 5, 2005 | 06:36 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome cldoug11, to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 5, 2005 | 07:31 AM
96_4wdr's Avatar
96_4wdr
check the driveline U joints, about time they go out, 185k
and spline shaft into tranny for wear
also check pinion shaft on rear end for wear, noise will carry into engine/tranny area up drive shaft.
Old Sep 5, 2005 | 09:41 AM
texans's Avatar
texans
if the noise gose away when you let off the pedal I would check the rear end. they have a tendency to make a hauling noise when they are going out or low on gear oil. then almost go away when you let off the pedal.
scotty
powerstroker100
Mar 20, 2012 10:41 AM
Explorer Freak
Feb 15, 2011 07:26 PM
BarnieTrk
1983 - 2012 Ranger & B-Series
31
Oct 15, 2008 09:29 PM
JIMMY663
2004 - 2008 F150
Feb 2, 2008 04:02 PM
