Offroad & 4x4
1997 4x4 not engaging!
Old Feb 21, 2005 | 06:25 PM
kdbbmanton's Avatar
kdbbmanton
I have a 1997 F150 SC that is not egaging into 4X4, the light comes on (4x4) and I checked the front drive shaft it is turning. So transfer case is operational. Front hubs are turning but no power is getting to them. The last time that 4x4 did engage was a week ago and it made some clunking noises when it did go in, and kept popping back out. I checked the Acuater or selonoid what ever it is, on the front axle it is also engaging when shifted in and out of 4x4. Please HELP in any way that you can. Thank You!
Old Feb 23, 2005 | 10:14 AM
dave74-360bb's Avatar
dave74-360bb
is it electric with vacum that engages your 4 wheel drive? if it is you may have a vacum leak
Old Feb 23, 2005 | 11:04 AM
kdbbmanton's Avatar
kdbbmanton
4x4 not working
Yes it is electric with vacuum, I have watched the vacumm engage all the way on the front axle, seems to be working ok?
Old Feb 27, 2005 | 03:20 PM
csbowser's Avatar
csbowser
Can't help you too much, but I believe there is an electronic clutch that controls the speed of the front driveshaft - it syncs up the front and rear driveshaft speeds. It could be that the clutch isn't allowing enough power to get to the driveshaft. Not sure how you could test that, but it is something to consider.
Old Feb 28, 2005 | 07:08 AM
kdbbmanton's Avatar
kdbbmanton
thanks for the input, I will check it out!
Old Mar 4, 2005 | 04:23 PM
Blue Rage's Avatar
Blue Rage
Just put a set of manual hubs on it and problem solved if you t-case is working properly.
66with352
1997 - 2003 F150
Jan 21, 2017 05:43 AM
inabind15
Jan 8, 2016 09:34 AM
4x4greenbeast
17
May 22, 2014 12:10 PM
Dan Ward
2004 - 2008 F150
Mar 16, 2009 07:56 PM
iamcanuck
1983 - 2012 Ranger & B-Series
Aug 23, 2004 09:35 PM
