86 302 efi cuts out
Old Nov 4, 2001 | 10:08 PM
Fordtruxrok's Avatar
Fordtruxrok
86 302 efi cuts out
I have an 86 f150 w/eec iv 302. It runs fine except when the engine gets around 180 deg or higher. The engine will cut out and barely run. I've checked the fuel pumps, replaced the hp pump, checked the fuel pump relay, replaced the eec relay and changed the ground in case thet was bad. No luck. I've heard about a pip signal problem, so I wired the fuel pump relay to energize with the ign switch. Now I figure there is something that is being effected by the engine heat that either kills the ignition sys or won't cycle the injectors. The ign module is a new Napa echlin module, cost me $80, I don't think that is my problem. I rebuilt the dist with a new pick-up, so that's not the problem. Today I looked over the entire engine harness and didn't find any burned bare or broken wires. I'm on the end of a rope here and goin nuts cuz I can't figure this out!!! Somebody help me!!!
John
86 F150
efi 302
Fresh C6 with alto reds, b&m shift, Tci 2200 stall converter
Old Nov 5, 2001 | 08:13 AM
paulieman's Avatar
paulieman
86 302 efi cuts out
I have the EXACT same problem guys, how bout you kill two birds with one stone so to speak here!
Thanks!
Old Nov 6, 2001 | 03:43 PM
paulieman's Avatar
paulieman
86 302 efi cuts out
umm PRETTY PLEASE? Forgot to mention, my trouble seems to be too much gas, but it acts like it's out of gas.
Old Nov 8, 2001 | 03:44 AM
scupbarron's Avatar
scupbarron
86 302 efi cuts out
Sounds similiar to problem I had in my 1988 f-150 w/302. I first changed cold start scensor ..was fine for a month then acted up again. After that I replaced IAC and havent had problem since. IAC's tend to get carboned up with old age ...was told you could renove and clean up but best to replace. Part I think was 85.00 for IAC, 35.00 for cold start scensor.
Old Nov 8, 2001 | 01:32 PM
paulieman's Avatar
paulieman
86 302 efi cuts out
What is the IAC?
Old Dec 2, 2001 | 11:59 AM
rocky2's Avatar
rocky2
86 302 efi cuts out
Old Dec 2, 2001 | 06:58 PM
paulieman's Avatar
paulieman
86 302 efi cuts out
>Somebody help me!!!
>John
>86 F150
>efi 302
paulwjax
Mar 26, 2014 11:21 AM
Trublufords
Jan 13, 2009 06:27 AM
toyota1988
Electrical Systems/Wiring
19
Mar 28, 2006 12:03 PM
Xtreasurehunter
15
Mar 11, 2006 10:00 PM
paulieman
Dec 3, 2001 11:47 PM
