Fordtruxrok
Old Dec 2, 2001 | 07:01 PM
paulieman's Avatar
paulieman
Fordtruxrok
Ever figure this one out? Sound slike my problem..
I have an 86 f150 w/eec iv 302. It runs fine except when the engine gets around 180 deg or higher. The engine will cut out and barely run. I've checked the fuel pumps, replaced the hp pump, checked the fuel pump relay, replaced the eec relay and changed the ground in case thet was bad. No luck. I've heard about a pip signal problem, so I wired the fuel pump relay to energize with the ign switch. Now I figure there is something that is being effected by the engine heat that either kills the ignition sys or won't cycle the injectors. The ign module is a new Napa echlin module, cost me $80, I don't think that is my problem. I rebuilt the dist with a new pick-up, so that's not the problem. Today I looked over the entire engine harness and didn't find any burned bare or broken wires. I'm on the end of a rope here and goin nuts cuz I can't figure this out!!! Somebody help me!!!
Old Dec 2, 2001 | 07:25 PM
Mil1ion's Avatar
Mil1ion
Fordtruxrok
Maybe it's time to invest $30-40 and buy a de-coder for FORD.
Equus sells one for about the above price.
Do a scan and let the computer tell you what the problem is.
The fuel pump should have already been wired to the ignition.
Dennis
First Came the Chicken,
Then Came the Egg,
Or Was It the Other Way Around?
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Dec 2, 2001 | 08:31 PM
JimM71's Avatar
JimM71
Fordtruxrok
The responses for the below post describe how you can check your codes without purchasing a decoder. I am new to this web site and do not know if there is a way to directly link you to the post.
"86 e150 302ci efi code scan", 17-Oct-01, 10:55 AM (EST) from albesure.
Old Dec 3, 2001 | 10:24 AM
paulieman's Avatar
paulieman
Fordtruxrok
It's in the shop, he isn't getting any codes....hooked up a break out box and is getting a 4.1 from the computer/engine ground, says it should be around .1-.3 so that may be the problem....I sure hope so cause i miss my truck!
Old Dec 3, 2001 | 11:47 PM
Franklin2's Avatar
Franklin2
Fordtruxrok
HD
13
Jan 9, 2016 07:05 AM
Trublufords
Jan 13, 2009 06:27 AM
toyota1988
Electrical Systems/Wiring
19
Mar 28, 2006 12:03 PM
Xtreasurehunter
15
Mar 11, 2006 10:00 PM
Ranger88
4 Cylinder Engines
Dec 1, 2005 01:30 PM
