Light problems on 1986 F150
Old Dec 9, 2001 | 09:02 PM
gun38's Avatar
gun38
With heads light switch off, I press the brake pedal and brake lights and license plate lights come on. Left turn signal gives me left turn signal while right gives me both left and right signals. With head light switch on I get no brake lights at all or running lights. This problem is all rear, front seem to work okay. What is possible problem? Turn signal switch assembly? Ground? Bruce
Old Dec 9, 2001 | 09:21 PM
Franklin2's Avatar
Franklin2
Pull the bulbs out and make sure they are oriented correctly, you'll notice one pin on the bulb is lower than the other. While your in there scrape all the terminals in the socket, and make sure the ground wire has a good connection to the body. If the glass part of the bulb is loose in the metal part of the bulb, replace it as the common of the bulb can break where it is soldered to the metal part.
Old Dec 9, 2001 | 09:25 PM
Franklin2's Avatar
Franklin2
Old Dec 9, 2001 | 09:27 PM
Franklin2's Avatar
Franklin2
[updated:LAST EDITED ON 09-Dec-01 AT 10:33 PM (EST)]computer is going wacko
Old Dec 10, 2001 | 07:08 AM
slikness's Avatar
slikness
Yeah, check your bulbs...it's amazing how much a blown bulb can screw up tail lights.
Slik
Old Dec 10, 2001 | 07:12 AM
slikness's Avatar
slikness
thatsrealnice
16
Jul 31, 2020 06:00 PM
Bdox
Electrical Systems/Wiring
Aug 27, 2008 10:36 AM
uk1050
Jun 29, 2006 10:38 PM
ClassicFinish
Mar 7, 2006 04:05 PM
