A/C problems
Old Feb 20, 2005 | 07:13 PM
5.8turtle's Avatar
5.8turtle
A/C problems
I have a 1994 F-150 flareside with a 351. My a/c used to be cold as ice and all of a sudden a few weeks ago it stopped getting cold (i live in florida). i was wondering if buying and adding refridgerant 134a would work or not for my problem or if it is somthing more.
Old Feb 20, 2005 | 08:32 PM
Kansas-Mike's Avatar
Kansas-Mike
It sounds like its just low..... But check the system hoses.... For cracks, bubbles, deterioration.... Your AC runs on R-134a? I thought they changed that in 95? Maybe someone can give us some more help...
Old Feb 21, 2005 | 04:50 AM
tex94F250's Avatar
tex94F250
'94 is 134A same as in my '94 F250. If the refridgerant level drops too low it will not run. Start with a recharge, then check for leaks.
Old Feb 21, 2005 | 09:24 AM
GermanGuy's Avatar
GermanGuy
I had the same problem on my '94 F-150 a few weeks ago and finally found the pressure switch (located on the accumulator) broken. This switch cycles the compressor.
LoL Dieter
Old Feb 21, 2005 | 11:23 AM
Kansas-Mike
Tex
Does ford make a sight glass to see if there are bubbles in the line?
Old Feb 21, 2005 | 12:31 PM
tex94F250's Avatar
tex94F250
My sight glass in on the driver's side of the engine compartment near the radiator. It has a plastic cap over it and looks like it might be a fill port to the uninitiated. If you cannot locate it I'll put a picture of it in my gallery later and advise you.
Old Jun 17, 2005 | 12:33 PM
DoratheExplorer's Avatar
DoratheExplorer
Can somebody please help!!!!!!!!!!!!!!!! I have had problem after problem with my AC. I have a '92 Explorer and so far I have replaced the hose assembly (was leaking), the compressor was a piece of crap, vaccuumed it down and refilled with 134. It ran cold the first coupl of days, then just kinda cool and now not really. I was told to replace the orifice tube, vaccuum down again and refill. What do you think?
Old Jun 17, 2005 | 03:53 PM
Popa Tim's Avatar
Popa Tim
Dora,
Head over to the A/C forum. There is lots of info on whats needed to convert to R134a.
