ignition help
Old Feb 20, 2005 | 12:12 PM
jndeere's Avatar
jndeere
ignition help
I have a 72 ford f100 Ranger XLT. How hard is it to replace the ignition switch in the steering column and the lock mechanism onthe doors? Thanks.
Shaun
Old Feb 20, 2005 | 08:55 PM
arcticoffroadingfish's Avatar
replacing the ignition switch is relatively quick and easy it one nut on the back a wire connecter. the locking cylinders on the doors are a little harder though when i did mine it took about 40 minutes a door but i have never done them before.
Old Feb 21, 2005 | 07:47 AM
jndeere's Avatar
jndeere
Do i Need to break into the steering column some how or is there and easier access.
Old Feb 21, 2005 | 11:03 PM
your ignition switch in the column didnt read that part sorry. then you need to remove the collar and to do that i beleive you need to remove the steering wheel also then it is all a mater of pulling the pin that the switch is hooked to for a return to the run postion and unhooking it. it will just take a little longer.
