slip yoke
Old Jul 26, 2000 | 04:56 PM
tmcalavy's Avatar
tmcalavy
slip yoke
Hey guys,
I've got a clunk or thump in my 90 F150 SC with 4.9L and E4OD whenever I put it in reverse or drive. Sounds kinda like u-joints, but there's no slop apparent when I get under there and muscle the driveshaft around. I've read about greasing a slip yoke to make a clunky driveline quiet down. Okay, I'll try anything once, but where and what is the slip yoke and how do I get it off to grease it? My truck has a two-piece driveshaft, with the hanger joint half-way in between.
Old Jul 26, 2000 | 08:03 PM
Eddie's Avatar
Eddie
slip yoke
Coming out of the back of that center bearing is a splined shaft which directly inserts into the cylindrical part of that slip yoke. A zerk fitting is located on the circumference of the cylinder, about three inches rearward toward the U-joint.
Check those U-joints again, though. Sure sounds like them to me.
Ed
Old Jul 28, 2000 | 01:31 AM
CJay's Avatar
CJay
slip yoke
Make sure when you check the u-jonts the truck is in neutral without the e brake (block the tire)and on flat ground.If it is in park there is to much tension to properly check them.You can also check the slip yoke the same as the u joints if it has play lubing it wont help much.If it is wore out the spline on the shaft probably is too. It would also be a good idea to check the play in the rearend while your down there.
Good luck.
Old Dec 12, 2001 | 01:36 PM
Franklin2's Avatar
Franklin2
slip yoke
Old Dec 12, 2001 | 11:37 PM
rocky2's Avatar
rocky2
slip yoke
When your checking for slop do you have the rear wheels off ground?You could have no slop detected with wheels on ground when there is bad u joints.
ohmyf150
Apr 9, 2014 08:12 AM
Junx69
Jul 1, 2013 11:49 AM
bbf150
Apr 9, 2013 09:02 PM
camccardell
Sep 16, 2008 06:49 AM
Grease
Sep 6, 2004 08:30 AM
