Sponsored by: Real Truck
Ford VIN decoder has some problems
Old Feb 20, 2005 | 06:33 AM
Photogman's Avatar
Photogman
I used the Ford website decoder for my VIN to see what it would return on my 2005 F250 V10 SWB Crew.
This forum software will not let me post links because I am under 25 posts....sorry guys, it's the software
My VIN is
The decoder said my engine was a diesel.....go figure...I've got the V10.
It also said the V10 had 305 brake horsepower.
Ford advertises it in all their brochures as 362 horsepower.
Is the 362 horsepower brake horsepower or rear wheel horsepower? I really am at a loss to understand the discrepancy in this published info
Old Feb 20, 2005 | 04:37 PM
04superduty's Avatar
04superduty
i would not show your vin #, either delete it or get a moderator to delete it for you.
Old Feb 20, 2005 | 08:09 PM
Photogman's Avatar
Photogman
thanks for the heads up.....live and learn
Old Feb 20, 2005 | 10:52 PM
cwilli's Avatar
cwilli
My V10 VIN also shows as a Diesel. It created a little angst after I ordered it because I thought they got the order wrong.
Old Feb 21, 2005 | 08:04 AM
captchas's Avatar
captchas
Guest
i just did mine same thing v10 is listed as a diesel. i thought s was the code for the v10 not the y
Old Feb 21, 2005 | 05:12 PM
captchas's Avatar
captchas
Guest
Post
i did some double checking and found that the engine code y is used several times. in the light med truck y is the 6.8 v10 but in the over 11 k rating y is used for the diesel. so to me it looks like it ford has a software problem in the gvw engine code area . every thing else came out correct. if any one can't find the sheet i did save it so i can foward if wanted
vee10td
Modular V10 (6.8l)
Jan 5, 2013 11:22 AM
vee10td
Modular V10 (6.8l)
Jul 5, 2010 03:00 PM
vee10td
Modular V10 (6.8l)
Feb 6, 2008 12:04 AM
alchymist
Modular V10 (6.8l)
19
Nov 16, 2007 08:34 AM
marbilupton
New Member Introductions
Nov 7, 2006 07:44 PM
