Carb problems....
Old Feb 19, 2005 | 08:53 PM
55FordLover's Avatar
55FordLover
Unhappy Carb problems....
Gentlemen and some ladies,
I need help in setting my carb....this is my first build and my engine is running to lean....lots of black stuff coming from the pipes...I have an edelbrock 600 and need some tips on adjusting the carb....
James
54 Ford F100 302/AOD
Old Feb 19, 2005 | 11:59 PM
LxMan1's Avatar
LxMan1
Well, if you have a lot of black smoke/ soot coming from the pipes, then it is running too rich, not too lean. Unless the choke is not opening, then I would check the float level first. Sounds like one or both floats could be too high.
Old Feb 20, 2005 | 08:17 PM
55FordLover
thanks for the fast reply...i found out how to adjust the carb on the net....its running okay now...but i need to clean the pipes and check it in the morning....
Buildingdavej
Sep 23, 2016 07:16 PM
KOMBILOVE
Mar 8, 2016 09:21 AM
mikeinmilton
Jun 10, 2015 03:10 PM
ColtonMullis
Apr 30, 2014 08:47 PM
K9sicem
Dec 27, 2013 07:33 PM
