dipstick smoking?
Old Feb 19, 2005 | 06:42 PM
jadel's Avatar
jadel
Question dipstick smoking?
I own a 94.5 7.3 psd F450 superduty with about 180,000 miles on it when warmed up and idling there is what looks like smoke coming from the dipstick,is this what you call base compression and what kind of trouble am i looking at
Old Feb 19, 2005 | 08:38 PM
RedStroker6's Avatar
RedStroker6
yeah....i noticed this the other day on mine. someone told me what it was one time years ago.....but i fergot.... i'll be watchin the thread.
Old Feb 19, 2005 | 10:04 PM
mcjones44us's Avatar
mcjones44us
I've seen the same thing on on my 2000 7.3, no other problems, so I haven't worried too much about it.
Old Feb 20, 2005 | 08:47 AM
Mike Allen's Avatar
Mike Allen
I am on my second 7.3 PSD and both have released a slight amount of smoke up through the dipstick. I suppose it is a bit subjective as to how much smoke is coming out of the dipstick if it is billowing out then there is a problem but if it is a small amount I would say no problems and it is normal.
Old Feb 20, 2005 | 09:45 AM
bodabdan's Avatar
bodabdan
Veteran: Navy
Most times that is caused by piston rings not sealing well. The gases in the combustion chamber leak past the rings and into the crankcase. The crankcase has a crankcase vent system that allows the excess pressure to exit the motor into the intake so that the engine reburs those gases. You may have a minor problem with the crankcase venting system. You may also have a problem with excessive blowby from the piston rings and the crankcase vent system can't handle all the gases coming from the rings.
Old Feb 20, 2005 | 11:25 AM
Kwikkordead's Avatar
Kwikkordead
I second bodabdan's comments.
Old Feb 20, 2005 | 12:01 PM
rollnthunder_76's Avatar
rollnthunder_76
Is it the dipstick or the filler tube?Just want to make sure what part it is.Also is it really cold outside because if it is you will see some steam coming from there because of the heat escaping from the motor.
Old Feb 20, 2005 | 01:46 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I would start by replacing or removing the little filter in the CCV on the valve cover. I would imagine in a 10+ year old vehicle it's probably close to plugged.
It's easier than a compression test and a ring job anyway.
GeoDan
Nov 21, 2010 08:18 PM
andrew1
Nov 13, 2010 09:18 PM
Brown Falcon
Feb 25, 2010 03:21 PM
chefrobert
1983 - 2012 Ranger & B-Series
May 14, 2007 09:51 AM
bdog12345
Apr 19, 2003 06:01 AM
