cam gear
Old Dec 23, 2001 | 08:51 PM
buckford's Avatar
buckford
cam gear
ok if i am changing the distributor on a (fuel injected converted to carb), the motor is out of a car 1986, i am going to use a 1980 distributor, it should work just fine, correct? what is the bit on the cam gear to a bronze, is this the internal gear or the external gear? thanks!
Old Dec 23, 2001 | 09:51 PM
Franklin2's Avatar
Franklin2
cam gear
I here about this all the time, but my engine builder said a Ford roller cam will work with a stock older style dist. I ran an 80 dist in an 86 roller motor for 8 years with no problem.
Old Dec 24, 2001 | 10:13 AM
64 merc's Avatar
64 merc
cam gear
RadioControlGuy85
Mar 9, 2014 02:19 PM
POPAJON
Mar 9, 2012 10:15 AM
gwhpnut
Mar 25, 2011 06:53 PM
Raxid
Engine Swaps
Nov 7, 2008 01:59 PM
77effie
17
Mar 27, 2006 10:36 AM
