1994 Explorer Intermittent Start Problem
Old Feb 19, 2005 | 11:44 AM
Nicks91Explorer's Avatar
Nicks91Explorer
My sons 94 Explorer 4.0 has an intermittent start problem. About 4 months ago after I put gas in the truck it would turnover but wouldn't start. I waited about 10 minutes and it cranked right up. Yesterday my son had the same problem with it. Waited aboput 10 minutes and it started right up. It has new plugs, coil, wires ,EGR, Fuel Press reg. From the search I just did is it likely to be the EEC or fuel pump relay? If so where is it located on the 4.0? Any suggestions would be helpful!
Thanks Mike
Old Feb 19, 2005 | 10:38 PM
mrshorty's Avatar
mrshorty
I don't know if I would call them "likely", but EEC and fuel pump relay are certainly possibilities. They are located in the power distribution box underneath the fuses. Power distribution box is under the hood, passenger side fender, near the battery and air filter housing.
When it won't start, do you hear the fuel pump run? The intermittent nature of this is going to make it difficult to track down.
Old Feb 20, 2005 | 10:41 AM
Nicks91Explorer
Intermittent Start
The first time I heard the fuel pump, I'm not sure about this time because my son is at college! I'll try the easy stuff first! Thanks for the reply, when I get it home I'll post on the fix!
Mike
mtodd101
Feb 19, 2017 12:15 PM
Turbo442
1997 - 2003 F150
Mar 25, 2015 08:43 PM
tsedgar
Oct 18, 2010 11:14 AM
leisureman
28
Jul 5, 2005 04:45 PM
jcgriffin
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
42
Mar 24, 2004 11:06 PM
