how many cfm??
Old Feb 19, 2005 | 08:08 AM
djmac's Avatar
djmac
how many cfm??
I have a transplanted 460 in my jeep j10. There is no shroud around the cooling fan and when I go off roading in turns into a giant propeller spraying mud all over under the hood. I even bent the blade due to the water and mud. At any rate I am thinking if would be a good thing to install an electric dual fan in a shroud like you see in the summit cataog. The question is how many cfm would be enough for a stock 460? I have no oil cooler or trans cooler and its an efi motor.
Old Feb 19, 2005 | 08:43 AM
rickk69er's Avatar
rickk69er
ya thats a good idea,i work at autozone go ther thell help u find the right fan, im getting redy to do the same thing also check the wreacking yards for a fan
Old Feb 19, 2005 | 11:01 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
i have a 780 cfm vacuum secondary holley on my 460, alot of people say thats too much for a stock 460, but i tell ya, it brought mine to life and ill never put a smaller carb on it, my friend had a 650 holley on his 460 and it had no guts at all, he put a 750 holley on it and now it keeps up with mine, well.....almost
Old Feb 20, 2005 | 12:34 AM
460f250's Avatar
460f250
I think he means the cfm of the cooling fans.
Old Feb 20, 2005 | 08:38 AM
SwOkcOffRoader
oooops, my bad, i seen cfm and 460 and assumed he meant carb... , that will teach me i guess....
Old Feb 20, 2005 | 09:17 AM
mclaughlin31's Avatar
mclaughlin31
djmac,
I would go with a 2500 cfm or possibly bigger, I made a very thin shroud out of metal that completely covered the radiator then cut it out for the fan assembly,At least you'll get full flow thoughout the radiator, I think I bought the flex-a-lite 210, says its good for 250 horsepower. I hoping that with the aluminum rad. I have, this will be enough, but I only had 3 1/4" from my pulleys to my radiator, didn't leave many options. Anyways, go with the biggest that will fit your truck and your budget and get one with a manual switch so you can shut it off for the high speed mud runs
James
Old Feb 20, 2005 | 10:04 AM
HOTWRENCH's Avatar
HOTWRENCH
Talking Cfm
Taurus fans work real well. Almost any of the fans from later
model air cond.cars move a lot of air.
Good luck HOTWRENCH
Old Feb 20, 2005 | 09:52 PM
spankin460's Avatar
spankin460
almost right ill take the challeng buddy im might have to spank that turd
Old Feb 20, 2005 | 09:56 PM
spankin460's Avatar
spankin460
would you put a fan on both sides of radiator?or side by side ?
Old Feb 20, 2005 | 10:14 PM
SwOkcOffRoader
this is what i get for inviting my friend to FTE and talkin smack about his rig!!
your on bro!! only Ill be the one doin the spankin!!!
Old Feb 21, 2005 | 11:41 AM
djmac's Avatar
djmac
thanks for the tips. a switch would be a great idea and we had a taursus and i remember the fans would really kick em out. if i got one on out of the junk yard i would have to pick up a thermostatic switch to control it. any suggestions on what one?
Old Feb 21, 2005 | 05:45 PM
HOTWRENCH's Avatar
HOTWRENCH
Talking Fans
You can buy an adjustable fan switch/ relay wiring kit from
summit or jegs. I just get into a napa switch book @ look for one that has the temp range im looking for. I try to find a fan relay out of a junker, but napa also has these. Most of the time i like to put a master override switch in for stop@ go traffic @ really hot days. On our mud buggys we have been mounting the radiators behind the cab in the bed. This lets us seal up the engine compartment really well. It also keeps the radiator a lot cleaner!
HAVE FUN HOTWRENCH
Old Feb 25, 2005 | 01:55 PM
djmac's Avatar
djmac
Good luck HOTWRENCH
Hotwrench,
When you indicate the taurus fans if I remember right they have 2 fans. 1 for the radiator and the one next to it was wired to come on with the a/c. Would i need both of these fans to get enough air? And do the come in a single shroud or are they mounted separately?
Old Feb 26, 2005 | 07:45 AM
HOTWRENCH's Avatar
HOTWRENCH
I used both fans , the ones I used were mounted separatly.
Good luck HOTWRENCH
Old Feb 28, 2005 | 06:20 PM
efi460's Avatar
efi460
junk yard fans
The taurus fan is good, but the mark VIII fan is the highest flowing fan factory or aftermarket IMO.You have to have a 130 amp. alt. to power it.
Do a google search for mark VIII fan someone has a web "how to" for a mustang.
I have a $30.00 taurus fan on my turbo coupe with a $17.00 autozone thermostatic switch and it works great.
