Which Carb?
Old Feb 18, 2005 | 05:08 PM
hayhauler's Avatar
hayhauler
Which Carb?
I need some ideas for a carb. I have a 1976 F-250, with a 1971 460 in it. It has a mild cam, edlebrock intake, and 10.5 to 1 copression. I plan to use this truck for towing. I've asked a couple of shops for their input on what CFM I should have, and none of these suggestions have come back the same. Right now I have Edlebrock 600 on it, and it does not perform well, so I am switching to Holley. Any suggestions, and ideas, would be great. Thanks Jason
Old Feb 18, 2005 | 05:25 PM
Mil1ion's Avatar
Mil1ion
Welcome to the site
This is a CARB application to an engine question NOT a 73-79 specific topic.
https://www.ford-trucks.com/forums/s...d.php?t=248773
https://www.ford-trucks.com/forums/s...d.php?t=102632
Therefore it will be moved to either the 460 or Fuel delivery forum.
Old Feb 18, 2005 | 06:24 PM
deerhunter3814's Avatar
deerhunter3814
Jason,
Try a holley 3310, it is a 750 vaccum secondary with manual choke. It will give your engine all it needs.
Good luck,
David
SwOkcOffRoader's Avatar
SwOkcOffRoader
take a look at this thread:
https://www.ford-trucks.com/forums/s...0&page=1&pp=20
a few of us are bickering back and forth about little stuff, but I tell my opinion about Holleys, and some others complain about em, then a few back me up...personaly i would put a 750 vacuum secondary on yours, set the timing at 12-14* BTDC and buckle up!!
Old Feb 18, 2005 | 11:36 PM
LxMan1's Avatar
LxMan1
Well, I run a 750 Edelbrock on my (mild) 460 and it runs great.
Old Feb 19, 2005 | 11:08 AM
hayhauler's Avatar
hayhauler
Is it vacuum or mech secondaries? Dbl pumper? When you say mild, what exactly are you meaning? What do you use your truck for? Thanks for taking the time to help. -Jason
Old Feb 19, 2005 | 12:05 PM
LxMan1's Avatar
LxMan1
It has an Edelbrock Performer intake, headers, CompCams 268H cam, lifters and matching valve springs, and an Edelbrock double roller timing chain installed straight up.
All Edelbrock carbs are mechanical secondaries with a secondary air valve to prevent hesitation when opening the 4bbls. I use it for towing and daily driving.
Old Feb 19, 2005 | 11:32 PM
hayhauler's Avatar
hayhauler
Thanks for the input, this realy helps! Keep enjoying your truck, and I will do the same. -Jason
fromm
May 6, 2010 01:31 PM
1972fordf-100
Dec 18, 2008 12:19 AM
gtuttle
Nov 9, 2008 07:17 PM
73 ford guy
Offroad & 4x4
13
May 20, 2008 05:00 PM
palmrose2
Sep 22, 2004 09:31 PM
