Driving along in 94 Explorer when suddenly it slipped out of gear. Pulled it over and tried to shift into other gears, put no gears will engage. Only have neutral.
Over the previous several months, I had been having trouble with getting it to shift. I usually had to rev it up and quickly release the gas to get it to shift. About a month ago, I had replaced the fluid, changed the filter, and even replaced the vacuum modulator. Still didn't shift correctly, but at least it worked. Now I have no gears and it's sitting alongside the road.
I can get it to drop into gear and it just barely creeps along (maybe an inch in five seconds). When I put it into gear, it makes a "whirring" sound. If I give it gas and let off, sometimes the whirring sound goes away. Fluid level is good.
