Tranny fluid
Old Feb 17, 2005 | 09:56 PM
reno_the_dog's Avatar
reno_the_dog
Tranny fluid
I just put a rebuilt tranny in my 74 pickup. It has a C6, but I don't know the amount of fluid it will take to fill it up. Any clues?
Old Feb 17, 2005 | 10:10 PM
schafer1's Avatar
schafer1
about 22 quarts I believe, if converter new and dry it might be more,dump in 8 qts, see if it shows on stick, if not 3 more at a time untilit hits the full mark not over filling,start up and let oil pump through tranny, bleed air out of tranny by putting it in low and reverse back and forth holding the brake if it moves you are getting close, let it warm up a bit and recheck if it dont move shut it down check and add more oil untill it will move, check when hot fill to safe operating range and drive it check for leaks daily for a while and recheck fluid level add as needed, record amount used.
Old Feb 17, 2005 | 10:15 PM
Mil1ion's Avatar
Mil1ion
Transmission questions like this should be posted in the transmission forum.
Old Feb 17, 2005 | 10:31 PM
reno_the_dog
Thanks shafer.
I figured a fairly simple spec question would probably be able to be answered here.
If I were needing to know how much engine oil it takes, should that be asked in my specific engine's forum?
Old Feb 17, 2005 | 11:04 PM
Mil1ion's Avatar
Mil1ion
Btw, Welcome to FTE!
Yes in the engine it pertains to
This forum is way too busy to be posting Systems Specific type questions.
Doing so Pushes the the REAL: 73-79 specific threads to the next page.
We have Thousands of members & thousands of hits & Posts a day.
But, It's really an easy system.
If the C6 was put in trucks for 16 years how does that make it a
73-79 Truck SPECIFIC question.
Have you read the READ FIRST: threads attached to the top of this forum ?
Old Feb 17, 2005 | 11:25 PM
deerhunter3814's Avatar
deerhunter3814
I just had my C-6 rebuilt, it is going in a 1978 F-150 4X4. It has the deeper pan like you find in the big mercurys of the 70's, the transmission shop told me to start out with 6 qts. I plan on getting a second opinion.
Don't be offended by Dennis, after all look at that mug, anybody with that fat face has to be about 4 foot 8 inches and about 300lbs.
Just kidding, Dennis has set me straight before and we need people like him to keep this site on the net for us.
Dennis, don't cast your wrath on me.
David
Old Feb 18, 2005 | 09:37 PM
schafer1's Avatar
schafer1
I am not to sure on these forums myself, I am just learning on thes computers haha.
Old Feb 21, 2005 | 03:30 PM
deerhunter3814
I just put my trans in and I put one quart in the torque converter (3500 stall) and six in the tranny after I started it I add one more, then after it was fully warm I had to add one more. That makes a total of nine.
David
Old Feb 21, 2005 | 10:23 PM
beeboy's Avatar
beeboy
according to my Haynes manual,in 74 the 2wd C6 took 28 Pints, 4WD took 26.5 Pints. I just changed the fluid in my 79, including the TC and it took about 13 quarts to refill it.
Old Feb 21, 2005 | 10:38 PM
deerhunter3814
I run a 9 inch converter, maybe that is difference? But 9 pts has it full, Of coaurse I will check it before every race, as always.
David
Old Feb 22, 2005 | 09:00 AM
schafer1's Avatar
schafer1
sounds good to me
Old Feb 22, 2005 | 09:24 AM
deerhunter3814
David
Well I meant to type 9 qts, not pts.
I should have taken typing in school.
David
FordLou
1997 - 2003 F150
13
Dec 10, 2014 09:36 PM
tndiesel
Nov 17, 2007 05:30 PM
mtgrzlyman
Sep 6, 2003 09:04 PM
dzk007
Aerostar
Apr 13, 2002 11:13 AM
EJonesJr
Jun 3, 2001 09:53 PM
