Explorer Cat Converter?
Old Feb 17, 2005 | 05:02 PM
stutterstan's Avatar
stutterstan
What causes the cat to clog?. How many cats are on a 4.0 Explorer. How hard of a job it is for a shadetree. Local mechanic told wife that the cats are clogged and wants 500 to replace (2) cats, needless to say I'm leary.
Old Feb 17, 2005 | 06:26 PM
mrshorty's Avatar
mrshorty
The engine running rich will clog cats.
From what I've gathered, Ford uses two cats. One reduces hydrocarbon emissions, the other reduces NOx emissions. Most aftermarket cats combine both operations into one converter.
Old Feb 17, 2005 | 07:21 PM
OneBang's Avatar
OneBang
What year is it? I work at Ford in Hazelwood Missouri and build 'em. Right now we have one on each side of the y-pipe. It's changed as one piece. Drop the crossmember, 2 nuts to each side manifold, 2 spring bolts to the muffler. Pull 4 HEGO wires and change. With a new vehicle, a hoist and all the right tools, I can do it in about an hour.
Old Feb 18, 2005 | 06:58 AM
stutterstan
It's a 99 EXP with a 4.0 sohc. is there any welding or cutting that has to be done?
Old Feb 18, 2005 | 04:20 PM
OneBang's Avatar
OneBang
Offhand I can't exactly remember the '99. If it's like they are now you would just replace the y-pipe assembly. There would be no cutting or welding unless it's REALLY rusted. If you replace just the converter, you would have to cut it out and weld or clamp a new one in.
jdeeg4276
Jun 19, 2011 08:31 PM
seventyseven250
Exhaust Systems
Feb 13, 2010 08:38 PM
Cruiseomatic
34
Feb 7, 2007 03:48 PM
Fordfanz
Nov 24, 2005 07:28 PM
Bronco86
Exhaust Systems
Jan 27, 2004 07:31 AM
