flywheel bolts hitting
Old Feb 17, 2005 | 02:59 PM
hash's Avatar
hash
Dropped my '65 3 spd, sounded and felt like the clutch was slipping. The eng is a '66 390. The first thing i found was the clutch springs were hitting the flywheel bolts, the disc had much more wear on the eng side, the fingers on the pressure plate were worn from the t/o bearing, no contamination, there was loose metal bearing looking things in the bellhousing (about a doz).
What is going on?
Old Feb 17, 2005 | 07:27 PM
lee's Avatar
lee
Hi,
Last time I ran into this type problem the parts house had given me the wrong clutch kit when I was doing a clutch job on my 1970 F250 with a 390. Luckly I detected the error before I finished assembly.
I wonder if the wrong clutch was installed on your rig.
Lee
Old Feb 18, 2005 | 10:22 AM
hash's Avatar
hash
Thanks Lee,
I was wondering the same thing. Maybe the flywheel was machined to low?
The thing that has me and my buddies stumped was the metal roller bearings falling out of the bellhousing when we removed it. The B/H cover had dents in it from those things flying around.
Ty
Old Feb 18, 2005 | 11:33 AM
lee's Avatar
lee
Ty,
How big are these rollers?
Better take a look at the pilot bearing, it's the one in the rear of the crankshaft. I have had one come completely apart before.
How does the Throw out bearing look. Could the rollers have came there?
Lee
Old Feb 18, 2005 | 01:18 PM
hash's Avatar
hash
lee,
approx 5/16" long, 2-3/16 in dia, solid not tapered.
the t/o looks ok
the pilot is solid
the starter works, but could it be from there?
ty
Old Feb 18, 2005 | 02:36 PM
fordman300's Avatar
fordman300
was the clutch disk installed backwards? the springs stick out one side further than the other to clear the flywheel.
Old Feb 23, 2005 | 10:24 AM
hash's Avatar
hash
no, the scuff marks are on the correct side
rehrlich
1997 - 2003 F150
Dec 4, 2014 04:05 PM
FordOwnerJoey
Oct 5, 2013 07:34 PM
dyingtolive
15
Mar 29, 2012 11:56 PM
dsc
May 14, 2002 07:36 PM
