what is the part I need?
Old Feb 15, 2005 | 08:02 PM
bluejay164's Avatar
bluejay164
I asked a while ago and got no help but the drivers side door on my 98 expy will not open from the inside. The bar that goes from the door handle to the ( I don't know what the name of it is but it's what the 'bar' attached to to actually open the door) is bent and I need the other part I just mentioned. Anyone know the names of these parts so I can do a search to find them so I can replace them and maybe be able to get out of the drivers side door one of these days?
Old Feb 15, 2005 | 08:51 PM
bigjace8's Avatar
bigjace8
you may be referring to the door latch? the inside door handle will have a rod that connects the handle to the latch if the rod is bent it wont work right and wont open the door. i would first try to straighten the rod and see if that fixes the problem if not a replacement latch may be necessary
Old Feb 15, 2005 | 08:54 PM
bluejay164's Avatar
bluejay164
Id id try straitening out the rod but that didn't help. When you pull the door handle the latch seems to bend as well. Any idea where I might be able to find these parts? and is it hard to replace them?
Old Feb 15, 2005 | 09:45 PM
bluejay164's Avatar
bluejay164
found something but can't post the link here but thinking I might need to replace the latch assembly? anyone know how hard this would be?
Old Feb 16, 2005 | 10:52 AM
Bobkate6's Avatar
Bobkate6
Before you replace the latch assembly disconnect rod from handle and either push or pull the rod to see if door opens.If it does'nt open try Wd40 on latch assembly, I fixed an expoler handle this way
kev100
17
Apr 21, 2016 05:05 AM
52 USCG Panel
17
Dec 8, 2015 10:33 PM
0500757Arf
19
Nov 1, 2015 07:19 AM
F250_
Oct 13, 2015 08:06 AM
Odisvan
Aug 14, 2015 01:14 PM
