Painting Computer Case... ;)
Old Feb 14, 2005 | 08:01 PM
Traxxis's Avatar
Traxxis
Hello all...
I'm going to be painting a computer case this week, and it will require some detailed masking. Problem is, the paint ALWAYS seems to pull up everytime I go to remove the tape... any suggestions??? Do I let the paint dry too long? Or not long enough?? Should I use a tape other than masking tape???
Next question: The case is matte black, with a slightly rough surface. Should I prime?? If I prime... the color this emblem will be is Hugger Orange (yayaya... I know... it's a GM color... sorry ), so what color of primer should I use? Should I use just a black primer to fill in some of the rough stuff? Should I use a regular grey primer? Or should I use a white primer to maybe help brighten the orange??
BTW: I'm painting this by spray can (areosal). This is close to what I'm doing (upper right corner)... http://www.okstate.com/
Old Feb 15, 2005 | 06:27 PM
trike1946's Avatar
trike1946
Get an exacto knife to cut around the tape. Don't go too deep. I would use gray or white primer. Do a test panel on something else with each color, to see what the final color will look like. Good luck with it.
Old Feb 16, 2005 | 04:43 PM
chuck641's Avatar
chuck641
sand down the case with some light sandpaper to get and oils or gloss off, this may be why the paint is not bonding well. and when you pull the tape off dont pull straight up off the case, pull it to the side so it is not lifting the paint.
Jason
Old Feb 16, 2005 | 05:33 PM
Traxxis's Avatar
Traxxis
Thanks fellas.
Stan
filthy6
Jun 4, 2016 12:44 PM
jvmcc
Paint & Bodywork
Aug 29, 2013 08:31 PM
Cracker289
Paint & Bodywork
Jul 29, 2005 07:22 PM
Rancho*Ryda
Paint & Bodywork
Jun 13, 2005 07:08 PM
forddytube
Paint & Bodywork
Jan 17, 2004 09:12 AM
