Offroad & 4x4
4 wheel suspension?
Old Feb 14, 2005 | 10:13 AM
badass_f-150's Avatar
badass_f-150
Red face 4 wheel suspension?
Does anybody know where I can find a 4wd suspension kit to replace my 2wd suspension. I know I havta replace a bunch of stuff. Can somebody please tell me what exactly I need. My engine is an inline 6.
Old Feb 14, 2005 | 10:29 AM
Ryan50hrl's Avatar
Ryan50hrl
you will need springs, shocks, complete front axle, transfer case, tranny, and a driveshaft
Old Feb 14, 2005 | 10:36 AM
badass_f-150
whats ballpark on the cost of that? Do u know of a website that has a kit with all of that in it?
Old Feb 14, 2005 | 12:12 PM
chuck641's Avatar
chuck641
best bet is go to a junkyard and pull everything off a 4x4 truck .. or better yet buy a wrecked 4x4 with good running gear and just transfer everything over
Jason
Old Feb 16, 2005 | 02:31 PM
Pkupman82's Avatar
Pkupman82
If your truck is a 1980-96 half ton, all the 4x4 front axle and suspension will bolt right up underneath your rig. The axle pivot mounts and radius arm mounts on your 4x2 are the same as a 4x4. You will need the adapter plate for the transfer case, the transfer case, front and rear driveshafts, the floor plate with the proper hole(s) for your shift lever(s), and a front diff with a matching ratio to your rear axle ratio. Also you will need the factory 2 inch blocks for the rear (4x4s sit up higher) or you'll be squatting in the back. Your inline six has plenty of power to be run in a 4x4. All these parts can be found on 1980-96 F150s and Broncos at your local bone yard. Good luck!
dieselsubmariner
Aug 24, 2014 09:45 AM
AceFord7
2004 - 2008 F150
Jun 7, 2014 10:49 PM
jjuchems
Oct 18, 2010 10:12 AM
59flatbedford
Aug 11, 2006 06:30 PM
mavman4
Nov 10, 2003 09:24 PM
