Diesel Smoke In Cab?? Wth
Old Feb 14, 2005 | 09:02 AM
Dakrri's Avatar
Dakrri
When the weather is in the single digits, and I forget to plug in the engine heater, my F250 is hard to start. Twice now in the last month, when I try and start it, smoke (diesel) actually came through the dash vent and into the cab. What the heck would cause that? I lifted up the hood both times and could not locate where the smoke is coming from, except it seems like the passenger side around the firewall.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
As bad as this sounds, the truck starts and runs fine after it starts.
<o></o>
Dale
Old Feb 14, 2005 | 09:52 AM
mech2161's Avatar
mech2161
The clamp on the down (or up) pipe(s) must not be seated good. When it warms it expands and seals.
Old Feb 14, 2005 | 09:57 AM
Dakrri's Avatar
Dakrri
Diesels are new to me, how do I go about fixing something like that? Is hard to do? And is it costly?
Thanks
Old Feb 14, 2005 | 10:40 AM
edub32's Avatar
edub32
how old is the truck?? I'd go see a muffler shop and have your exhaust inspected
Old Feb 14, 2005 | 10:49 AM
Dakrri's Avatar
Dakrri
It is a 1999 F250 CC with 142,000 miles on it. I’ve been under the truck and the exhaust looks great. Still shiny. Maybe I can just tighten up the down pipe flange? I’ll take a look this weekend.
ckal704's Avatar
ckal704
"The clamp on the down (or up) pipe(s) must not be seated good. When it warms it expands and seals"
I agree with Mech2161.
You can tighten exhaust clamps yourself. You might want to drop some WD40 or similar on the nuts/bolts first and work it around so you can get an effective tightening. If the exhaust is leaking badly through a hole, you should be able to hear it and warming up shouldn't affect it's coming or going.
Old Feb 14, 2005 | 10:55 AM
mech2161's Avatar
mech2161
The down pipe is were the exhaust exits the turbo. Tap around the clamp with a hammer and try to tighten it. The up pipes are were the exhaust enters the turbo. Look for a black film were there might be a leak.
Old Feb 14, 2005 | 11:10 AM
Dakrri's Avatar
Dakrri
Thanks for the information guys, this is a great site, with good people, and great information.
Dale
