boost gauge help
Old Feb 13, 2005 | 03:21 PM
97_Ex's Avatar
97_Ex
boost gauge help
As I was installing my new gauges I ended up cracking the nylon tubing for my boost gauge as I pulled it through the firewall. Can I just get some 1/8 inch hose and run it to where my other tubing broke and attach it with brass fittings? Thanks for your help!
Old Feb 13, 2005 | 03:39 PM
Quadzilla's Avatar
Quadzilla
Yeah, if you get the right fittings you should be fine.
Old Feb 13, 2005 | 03:43 PM
97_Ex's Avatar
97_Ex
Man, I hate the nylon stuff that comes with the gauges. Its not long enough and it is sooo easy to bend!! Thanks
Old Feb 13, 2005 | 04:05 PM
Quadzilla's Avatar
Quadzilla
And, it gets brittle over time. I recently experienced a loss of boost, and found that it was nothing more than the 1/8" nylon hose had developed a crack in it, which eventually broke off in my hand while inspecting it.
Old Feb 13, 2005 | 04:15 PM
Saguaro_7.3's Avatar
Saguaro_7.3
I'm probably going to get some gauges in the next couple of months - pre-pyrometer, boost, and tranny. I guess I should expect to buy some REAL hoses for the pyrometer and boost before I put them on.
Old Feb 13, 2005 | 04:20 PM
97_Ex's Avatar
97_Ex
Pyro doesnt use a hose but as far as the Boost goes I guess its up to you, I really dont like the nylon stuff but most people use it.
Old Feb 13, 2005 | 04:25 PM
Saguaro_7.3
You're right, I stand corrected. Think I will get a good hose and do it once.
Old Feb 13, 2005 | 05:14 PM
FAB150's Avatar
FAB150
Are any of you using air line stiffners with the 1/8 line? If where did you find it? I found them for 1/4 line but not for 1/8 line.
Old Feb 13, 2005 | 05:19 PM
kc2006's Avatar
kc2006
anyone else with a 94-97 have a problem finding a T fitting to put your boost gauge in? I put mine to the map line or whatever it is and its 1/4" i think so i had to put a piece of hose on the third part of the T fitting and rig it up to make it work. Do they make a 1/4" on the straight ends with a smaller third end?
