98 Expedition won't start--Theft indicator
Help! My 98 Ford Expedition won't start every time. It comes back with a code that says I am using the wrong key (not true) and activates the theft deterrence. I have been able to start it since the first time this has happened and took it to the dealer (who gave me the theft answer), but unfortunately it worked fine while there. It worked fine for a few days, but once again it is not starting with the theft light doing a fast blink when I try to start it. HELP! Any suggestions would be appreciated.
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards.
Enjoy FTE
I am experiencing a similar problem with the original key from the factory. I have 2 spares and both work. The original doesn't work at all. I know there is a problem with the original key. I also know there is a TSB on this problem. In my case I am just using the spares. I will eventually have the original replaced.
1998 Ford Expedition XLT 4.6 4x4
David Vox Mullen
Escape & Escape Hybrid
03-08-2024 07:45 AM
jdcpjc
01-17-2019 10:11 AM
