For those with 460's.....
Old Feb 11, 2005 | 10:21 AM
Caleb1's Avatar
Caleb1
what kinda gasmileage ya gettin ? No smart *** remarks please, it may seem stupid, but i'm curious. Thanks!
Old Feb 11, 2005 | 10:46 AM
Ford79's Avatar
Ford79
4-7, depends on how heavy my foot is that day.
Old Feb 11, 2005 | 11:45 AM
bulrydr_1's Avatar
bulrydr_1
I averaged about 4 1/2. Tore it to rebuild, and according to the all the specs, and a light foot, I should get about 10....
Old Feb 11, 2005 | 12:50 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
my stock 460 with a 780cfm holley vacuum secondary got 12-14 mpg if i kept my foot out of it, lately ive only been getting 8-10 because its overdue for some top end work.Before the valvetrain went downhill on me, 12-14mpg wasnt hard to achieve at all, even hauling a 16' trailor with a ditchwitch,2 1000' rolls of conduit, 28' ladder and a bunch of tools i could still get 12mpg. If anyone is getting less than 10mpg from their 460 they need a carb rebuild or their timing checked, or like me-need the top end reworked.....of course those numbers go down drasticaly if you like passing every chevy out there!!Which i do alot of the time, and thats why i need topend work as well...
Old Feb 11, 2005 | 03:06 PM
jim henderson's Avatar
jim henderson
Depends what year etc.
My 94 F250 supercab long bed E4OD 4x4 4.10 gets about 10-11mpg almost regardless how I drive. On a good day if I say my prayers, I might get 12mpg. Towing my 8,000# trailer I get 8-9mpg on flats and I have seen as bad as about 5-6mpg in nasty hills.
From what I have read most of the guys with EFI get between 9 and 12mpg. The carb'd guys get less.
Good Luck,
Jim Henderson
Old Feb 11, 2005 | 04:53 PM
Lou Braun's Avatar
Lou Braun
'95 F-250 HD with EFI - 12 MPG unloaded, 12.5 with a tailwind, 6-8 MPG when towing a 10K trailer.
As others have mentioned, it is *very* easy to get lower numbers if you stomp on it.
Lou Braun
Old Feb 11, 2005 | 07:13 PM
jonnybronco's Avatar
jonnybronco
My 88 F-250 with fuel Injection gets about 9-10 average. Lowest was 6 when pulling a trailer 75 mph on freeway, best was 12 when cruising about 55 on freeway.
Old Feb 13, 2005 | 07:36 AM
rogerfries's Avatar
rogerfries
I get 8-9 pretty much all the time, empty or loaded. I pull a 8000 Lb 26' Box trailer. I'm using a Carter AFB
Old Feb 13, 2005 | 09:37 AM
weldingfreak's Avatar
weldingfreak
I have an 84 F-240 4x4 hd ie. lots of weight empty almost 6000lbs farm truck motor with almost 200,000 miles on it and eats quart a week of oil it gets 8 mpg empty, 6mpg fully loaded 10,000lbs gravel driving off the scales
Old Feb 13, 2005 | 09:17 PM
Semper Fordelis's Avatar
Semper Fordelis
Gas Mileage???
The numbers that you guys are posting are crappy! I have an F250 with the 460, a 4 speed and 38's. The truck actually runs like crap but I towed a car down the highway doing about 70-75 mph and I got 12 mpg. My average gas mileage day to day is about the same. maybe i shouldnt tune it up, my mileage might get worse!!!!!
Old Feb 14, 2005 | 07:19 AM
DailyDriver's Avatar
DailyDriver
I'll echo the above. Mine is of 1975 vintage. I usually get 8 mpg in town and 11 hwy with a Holley 750cfm carb.
Old Feb 21, 2005 | 02:09 PM
resqpink's Avatar
resqpink
I've got a 93.5 FI 7.5 CC LWB 4X4, always got 13-15 mpg highway, light trailer, loaded,empty until I put 35s on it last year. I probably dropped 2mpg. She's been great, though, very reliable. I'm getting a diesel now, just hope it's as reliable!
Old Feb 21, 2005 | 06:24 PM
Selfhl1's Avatar
Selfhl1
Capt. Hugh
97 F-250 4x4 crew cab short bed, just went to SC about a 800 miles round trip and got 13.1 mpg
Old Feb 21, 2005 | 06:52 PM
QUEBEN's Avatar
QUEBEN
Question Vaccum lines on a 460?
I have my newly built 84 F250 4X4 (used to be a 2x4), up and running now but I have a few questions. When I bought the truck in Az in was in pretty bad shape, it still ran, or should I say limped along but it needed some TLC. I have finally got most of it straight, but I am wondering... My fuel tanks have breather valves, ( like I see in the manuals for a vaccum canister) and a vaccum set-up. Problem is ever since I have had the truck it has only had about 4 vaccum lines, one to the auto tranny (its now gone since I have a manual) and and one from the heater motor, plus the Manifold vaccum and temperature on the front of the engine... Should there be more? Its an 84 and it says non-catalytic, so no CAT either. I'm just trying to figure this all out.
Old Feb 21, 2005 | 10:59 PM
spankin460's Avatar
spankin460
my 460 gets about 9mpg but you really got to be easy with to get that
