Sponsored by: Auxito
back from ford update
Old Feb 11, 2005 | 07:27 AM
ruger9's Avatar
ruger9
Unhappy back from ford update
Ford replaced air temp sensor.zero change with rough idle.we will see about milage after fill up.Bummer I really hoped they found problem.
Old Feb 11, 2005 | 08:45 AM
BillyBob69's Avatar
BillyBob69
I dont remember if there was an original posts, but for the rough idle.....has the IAC been checked out or replaced?
Old Feb 13, 2005 | 09:58 AM
ruger9's Avatar
ruger9
reply
I mentioned iac to them but they don't check stuff out"no code no problem"is the moto of this shop.
I don't know how to check iac myself,Instructions?pictures?? thank you for replying.
Old Feb 13, 2005 | 10:11 AM
superrangerman2002's Avatar
superrangerman2002
That's bs as the IAC could be working just enough to not throw a code, but still bad enough to be noticed.
Old Feb 13, 2005 | 11:17 AM
fordman311's Avatar
fordman311
You can find tons of posts about IAC if you use the forum search tool. It's easy to replace. Check my gallery for help
Old Feb 13, 2005 | 12:48 PM
BillyBob69's Avatar
BillyBob69
The IAC is located st the top back of your intake manifold. Just remove the large plastic manifold cover, then unplug the harness to the IAC, then 2 bolts to remove the IAC. If its not too bad, you can clean it with something like brake parts cleaner, then blow it dry, replace and done. Or you can just buy another one for about $70. Easy to replace.
Ford79
Sep 22, 2011 09:41 PM
mgazak
21
Nov 18, 2002 11:51 AM
Vampiro
Oct 13, 2002 08:08 PM
Distinctive Dave
Sep 10, 2002 09:53 PM
mavman
1997 - 2003 F150
Mar 5, 2002 11:59 AM
