Blowing oil out
Old Feb 27, 2002 | 05:26 PM
ghambley's Avatar
ghambley
Blowing oil out
Has anyone else had this problem? I bought this 86 F-250 last month and it had a small oil leak from the valve covers. well I fixed that and it started leaking out of the rear main seal so I pulled the motor and replaced that. When I put the motor back in I left out a itake bolt well everything was fine no leaks untill I found the bolt after I put it back in the rear main stated leaking again BAD it will blow out a quart of oil in a matter of a few minutes but it only blows out 1 quart the engine is the original 460 with 116000 miles on it.
Old Feb 27, 2002 | 09:10 PM
topo4u2's Avatar
topo4u2
Blowing oil out
You might want to check your oil pressure, as it may be too high.
Old Feb 27, 2002 | 10:19 PM
Franklin2's Avatar
Franklin2
Blowing oil out
Check your pcv system and make sure it is evacuating the crankcase correctly.
Old Mar 1, 2002 | 02:33 PM
blupony96's Avatar
blupony96
Blowing oil out
I was fooled by my 302! Check your oil pan gasket.
Old Mar 2, 2002 | 09:13 AM
rocky2's Avatar
rocky2
Blowing oil out
You could be overfilling the crankcase.ID the dipstick.Drain oil and measure it.After it blows only one quart.And also make sure the rear intake gasket don't leak.(ford v-8 traint)And did you make sure the oil drain holes were clear?if you drop old rtv in side top of head it may cause pcv problems.
Old Mar 3, 2002 | 10:10 PM
ghambley's Avatar
ghambley
Blowing oil out
Thanks for the feed back. here is a list of things I have already done. draind the oil and refilled it 6 quarts with the new filter. new pan gasket, presure is 65 pounds at cold start up 25-30 after warm, changed pcv and checked line it is clear. so next is the new valley pan and check the heads.
Old Mar 4, 2002 | 09:22 AM
dezynco's Avatar
dezynco
Blowing oil out
GimmeYoLunchBox
Nov 10, 2013 11:26 PM
Lead_Pusher
Mar 29, 2010 04:34 PM
wantaford
17
Aug 11, 2008 01:15 PM
jonarotz
1983 - 2012 Ranger & B-Series
Sep 13, 2005 09:44 PM
d0n_3d
Dec 7, 2003 09:01 AM
