Clutch lever hitting header.
Old Feb 10, 2005 | 04:32 PM
padd54's Avatar
padd54
Please help, I installed Dynomax headers on my 68 F250 2wd w/390. The clutch lever (NP4spd) is hitting the collector not allowing the clutch to disengage completely. I can still shift but I can feel the clutch rubbing. Any suggestion on getting clearance?
Thanks, ray.
Old Feb 10, 2005 | 08:23 PM
xlt70black's Avatar
xlt70black
clutch hanging up
I had a 70' f100 360 std. with headers the clutch would hang up well the yoke would get hung up on the collector the simple but crude fix I used was get another clutch return spring hooked it thru the same hole as the exsisting clutch spring but I went up with this one and hooked it to the master cylinder put just enough tension to keep some upward tension on the yoke this worked for me for years never any problems hope this helps if this is the same thing yours is doing.
Old Feb 10, 2005 | 08:36 PM
rebocardo's Avatar
rebocardo
I had the same thing happened with my truck 390, except if was an exhaust pipe. I guess bending your header is out of the question ... Is it the square part at the very end that is hitting the header?
Old Feb 11, 2005 | 01:52 PM
bertha66's Avatar
bertha66
Padd54, I see my toughts from yesterday are gone, I hope that you got this fixed. Let me know if I can be more help to you.
Allen
Old Feb 11, 2005 | 03:16 PM
padd54's Avatar
padd54
Thanks everyone. I am going to the exhaust shop to have them cut off the flanges and weld the collector to the reducer.
Old Feb 11, 2005 | 06:56 PM
bertha66's Avatar
bertha66
That is good, I hope to see you around the Central Oregon area this summer.
Allen
jon.smith
Jan 30, 2014 04:30 AM
zak8tac
Mar 22, 2009 02:18 AM
padd54
Feb 11, 2005 03:18 PM
blatherskite
Dec 11, 2003 06:13 PM
slackerteam
Oct 20, 2002 04:34 PM
