solid vs. hydraulic lifters
Old Feb 14, 2005 | 06:33 PM
longview1's Avatar
longview1
Banned
Approximately how much more HP and torque are we talkin here anyway with solid cam?
Im gonna be doing a build here pretty quick, just getting as much info as i can.
Thanks
Old Feb 14, 2005 | 08:05 PM
fordeverpower's Avatar
fordeverpower
Not enough for a lazy man! So if you don't want to **** around use a hydraulic.
Old Feb 14, 2005 | 10:16 PM
longview1's Avatar
longview1
Banned
Hydraulic it is.....Im not entirely lazy, guess theres more to screw up with solid, Ill stick with hyd.
Old Feb 14, 2005 | 10:47 PM
mlf72f250's Avatar
mlf72f250
Originally Posted by krewat
...I kept the 390. Still need something to put it in
I'm used to mechanical lifters, I drove Triumph TR7's with overhead-cam that used shims to adjust the valve-lash...
art k.
Hmmm... How about a 390 in a TR7? Now that would be a sight!
Old Feb 14, 2005 | 10:49 PM
mlf72f250's Avatar
mlf72f250
Originally Posted by d44hd
...An FE will live comfortably with .016-.020 of lash, will run with a minimum of noise, and not burn valves...I run .018 with mine and its quieter than the hyd cam that came out, however the mfg designs a soild cam with a closing ramp to let the valves seat gently...If you start closing up the mfg's specs too much you may start to pound the valves hard against the seats and only bad things can come of that...
Thanks for the tips. Maybe I'll run 0.018" lash next time around. I'm kind of getting used to the rough idle. And wouldn't mind a little more lope. Afterall, this thing is going in a hot rod. ;-)
Old Feb 15, 2005 | 10:26 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Believe it or not, I measured a 360 to see if it would fit in a TR7 - it would, but only with a 4x4 pan (k-member in the way).
Darn engine compartment is huge - very wide - not long, but wide. I hung a 302 w/AOD in one just to look at - plenty of room. More room to change the spark plugs in a TR7 than a Mustang!
JTB321
19
May 7, 2016 01:31 PM
scottiethebarber
Oct 6, 2015 02:36 PM
BigBlocker0248
Jun 29, 2015 11:41 AM
Ki-Adi-Mundi
Apr 7, 2014 02:27 PM
wagonerkl
26
Jul 25, 2011 10:03 PM
