Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
do you bleed your compressor
Old Feb 10, 2005 | 09:32 PM
RyanMiller's Avatar
RyanMiller
I drain my compressor at home whenever i remeber it, useualy once a week, or if i use it alot i'll drain it more. That one stays pressureized all the time, but i shut off all the pipeing with a valve so that the tank stays pressurized without the pump clyling every few hours.
At work we have one that we shut off power to before we leave, and all the leaks in the system drain the air out over night. We useualy forget to drain the compressor, once we had about a gallon of water come out. I was working there about 6 months, and when i was sandblasting i was getting tons of water in the lines, i asked when the last time they drained the compressor was.. they just shrugged. i got a coffy can and drained it in there, and it filled about 3 coffy cants up with white water.
Old Feb 10, 2005 | 10:00 PM
dwoodler's Avatar
dwoodler
Bleeding your compressor right down daily won't hurt your compressor but unnecessary. At work we have a compressor with almost 250 gallons of standby air that is continually maintained to 110 psi. These tanks have been in place for over twenty years and none have developed leaks. They are the start air in a diesel powered power plant. There are automatic bleeders on them that blow off a little air now and then that removes some of the moisture but we do it manually every week to make sure they are empty of moisture. There is also an air dryer between the compressor and the storage tanks as well as a dual filters and moisture still gets in there. Just the way it is.
However, on my home compressor... I drain it off when I think about it and my old man did it about as often and that compressor is still chugging away after twenty or so years...
So I guess it kind of up to you and the habits you would like to get into. Just an opinion...
Don
Old Feb 10, 2005 | 11:37 PM
oldhalftons's Avatar
oldhalftons
Originally Posted by rebocardo
I bleed it and leave the drain **** open until I run it again.
Thats what I do.
Old Feb 11, 2005 | 04:49 AM
Torque1st's Avatar
Torque1st
Posting Legend
Mine is pressured up constantly, ready to blow out a computer or fill a tire. I have made sure there are no leaks in the system so I don't waste air. A good automatic drain valve is a good investment. Check for moisture monthly tho.
Old Feb 11, 2005 | 06:55 AM
Huntsman's Avatar
Huntsman
I also leave mine pressurized all the time but I did install a cut-off valve at the tank so I can cut off pressure to my airlines and hoses. I try to remember to drain the water from the bottom of the tank after each use. I have a 60 gallon tank and when I need to pump up a tire or blow off some dust, there’s always enough air in the tank without having to hear it run.
Old Feb 11, 2005 | 01:32 PM
omni's Avatar
omni
how exactly does a automatic drain valve work??
Old Feb 11, 2005 | 02:05 PM
maa139's Avatar
maa139
Yes I do. Time of year dictates how often. Usually in the winter I'm only using it on weekends so I'll open up the drain when I'm done to let all of the air and water out. In the summer, it's usually once a week.
Old Feb 11, 2005 | 02:19 PM
Vankaye's Avatar
Vankaye
I leave the valve open a hair so it's contantly hissing slightly.
When I'm done with the compressor I shut it off and the tank
drains automatically. If I forget to shut it off I will soon hear
it the comressor fire up reminding me it's still on. Just had
it serviced, and after 10 years it's in perfect condition.
Old Feb 18, 2005 | 05:41 PM
dwoodler's Avatar
dwoodler
Most auto drain valves are electric and use a timed solenoid to blow off some air/condensation at whatever interval that it's set to. This I find startling and usually makes me jump cause it's always when you forget about it.
Old Feb 18, 2005 | 09:19 PM
D305's Avatar
D305
I drain mine daily.
friskyjake
13
Mar 7, 2014 06:43 PM
ChuckRob
Jul 24, 2013 07:15 PM
knightshield
Garage & Workshop
18
Mar 7, 2004 03:24 AM
Wes64052
Garage & Workshop
Feb 26, 2004 05:06 PM
1968F250LWB
Mar 10, 2003 09:07 AM
