bleeding brakes
Old Mar 6, 2014 | 04:06 PM
friskyjake's Avatar
friskyjake
bleeding brakes
!995 f350 power stroke diesel srw 4x4 . What is the proper way to flush all the brake fluid from my truck? I do have a Mity vac. brake bleeding system. It uses my air compressor to make vacuum to pull out the old fluid tru the bleeder screws. I know to start bleeding the fluid & air from the farthest [r rear ] then the L rear what i,m not sure of is the next one to bleed [ the anti lock valve] & then the R front & then the L front? I guess I could go to a brake repair place & ask the questions But I thought other folks on this site could benefit from my questions. Thanking you friskyjake
Old Mar 6, 2014 | 05:08 PM
glovemeister's Avatar
glovemeister
RR,LR,RABS,RF,LF.
Good luck!
Old Mar 6, 2014 | 06:07 PM
tjc transport's Avatar
tjc transport
i ain't rite
i gravity bleed starting at the passenger rear. when all the old fluid is out of the system i close the pass rear and then do the driver rear. then pass front, and lastly driver front.
Old Mar 6, 2014 | 10:51 PM
oldbird1965's Avatar
oldbird1965
Finally, after all these years of saying gravity bleed, someone else says it too!! Thanks Tom
Old Mar 7, 2014 | 06:24 AM
tjc transport
i ain't rite
it is kind of hard to have someone step on the brake pedal when you are by yourself!!
i have been gravity bleeding brakes for many many years.
Old Mar 7, 2014 | 07:57 AM
rusty1161's Avatar
rusty1161
I have one of these Ford Three Tab Brake Bleeder 0107 and it works awesome. I have to try gravity bleeding, too. I never had a good experience with a vacuum setup.
Rusty
Old Mar 7, 2014 | 10:41 AM
friskyjake's Avatar
friskyjake
brake bleeding
Ok so if I have let all the fluid out of the system with all the bleed screws now tight I then fill the master cly. & start the bleeding all over again in the proper order. My concern is if the rabs [anti lock]. if it has internally moved how do you get back to center or where ever it has to be. If it is out of whack won,t it also cause a lite to be active on the dash. Thanks again every one. friskyjake
Old Mar 7, 2014 | 11:08 AM
madpogue's Avatar
madpogue
Isn't that what a snow brush (wedged between the seat and the pedal) is for?.... (Works for testing the brake lights, anyway.)
Old Mar 7, 2014 | 01:32 PM
tjc transport
i ain't rite
i use the vehicle behind me to test the brake lights.
if they don't hit me, the lights are working.
actually, i usually park close enough to something when i back in that i can see the brake light lit when parking, and also in the am when leaving.
Old Mar 7, 2014 | 02:50 PM
mjunk1's Avatar
mjunk1
I've never heard of emptying it all first. I always added new on top to keep the system from sucking in any air. Seems a little scary to me to let all that air in first and then try to push it back out. I'd be interested in whether others have let it all bleed out before adding new to the master.
Old Mar 7, 2014 | 03:26 PM
tjc transport
i ain't rite
same as if you blow a line. the master will gravity bleed out on the ground. it just takes a bit longer to get fluid back through all the lines
Old Mar 7, 2014 | 04:45 PM
oldbird1965
I'm with you Dan, I let the new stuff follow the old stuff out.
Old Mar 7, 2014 | 05:32 PM
friskyjake's Avatar
friskyjake
Are we talking about a brake bleeding on a truck with rabs or a non rabs. [anti rear brake lock]. up? No one answers about that extra valve. I,m sure it will shuttle inside the valve. If not ok but my concern is if it does move how do you make it rite again Thank you again for your ideas. Friskyjake
Old Mar 7, 2014 | 06:43 PM
tjc transport
i ain't rite
my 02 still has abs in it, i don't know if it works though. same with the 04.
both of them blew rear lines and bled out. i replaced the lines, cracked open the bleeders and filled the master up with no lights on the dash
fifty-two_f1
Feb 22, 2016 02:22 PM
F-250 restorer
Nov 15, 2010 10:28 AM
szilagyic
20
Jun 10, 2010 08:24 AM
hotwtr
Nov 17, 2009 06:58 PM
TXranger2003
Nov 22, 2005 08:43 AM
