bleeding power brakes
Old Mar 8, 2003 | 11:33 AM
1968F250LWB's Avatar
1968F250LWB
Quick question:
When you bleed power brakes do you run the engine or leave it off??
Old Mar 8, 2003 | 01:11 PM
1968F250LWB
Need help here. I am trying to bleed them and need to know what I need to do. Thanks guys.
Old Mar 8, 2003 | 01:25 PM
8NRay's Avatar
8NRay
It really doesn't matter. I generally don't start the engine because I don't want all that heat and fumes around while I working. They bleed just fine either way.
Old Mar 8, 2003 | 04:35 PM
1968F250LWB
Thanks. Any ideas on how to get a stripped out bleeder nut loose? Don't ask!
Old Mar 8, 2003 | 04:37 PM
heep70's Avatar
heep70
Leave engine off. Start bleeding with the closest to the master cylinder wheel first. Order: Drivers front, passinger front, drivers rear, and last passinger rear.
Old Mar 8, 2003 | 04:45 PM
sparky's Avatar
sparky
Vice grips the ultimate tool
Old Mar 8, 2003 | 05:50 PM
1968F250LWB
I have read on here that the order is reverse of that. So which one is it? Is it just a matter of preference?
LOL That is how it got stripped in the first place. You know this redneck reached for the vice-grips at first sign of strippage!!
Old Mar 8, 2003 | 06:10 PM
heep70's Avatar
heep70
I have read both way also but brake shops tell me the closest first. It works for me just fine.
Old Mar 8, 2003 | 06:33 PM
jor's Avatar
jor
Be VERY careful with the vice grips on the warbled bleeder valve. I would put penetrating oil on it several times over a 24 hour period. If it breaks, you're screwed and will have to do the easy out thing or replace the part.
On the order, I have always done farthest away first and a glass jar.
jor
Old Mar 8, 2003 | 06:47 PM
8NRay's Avatar
8NRay
You want to bleed the fartherest wheel cyl from the MC first, then next closest, etc. If you start with the closest first, the air in the fartherest will start moving to the MC so you will have to bleed more brake fluid when you get to the fartherest to get the air that has moved farther down the line back to the WC.
Old Mar 8, 2003 | 06:57 PM
heep70's Avatar
heep70
That makes sense. But either which way the air gets bleed out. Yes, it might move back towards the MC but it won't move down the already bleed lines. No matter if you end up bleeding farthest to nearest or the other way the fluid and the air gets pushed from the MC to the WC you are bleeding.
Both ways are correct, just don't let the air re-enter the bleed zerk after bleeding.
Old Mar 10, 2003 | 09:07 AM
jas88's Avatar
jas88
The best way to fix a stripped bleed valve is to replace the wheel cylinder. They are under $10 each at Autozone and you are going to bleed the system anyway. This is much easier, IMO, than fighting that thing under the truck with a pair of vise-grips.
Hobdy
36
Apr 22, 2019 04:44 PM
kilog55
26
May 9, 2017 07:37 PM
hurst1979olds
Apr 20, 2016 11:11 AM
crazyrwe
Nov 6, 2011 02:47 PM
Headviking
Jul 31, 2011 12:27 PM
