Manual transmission identification
Old Feb 10, 2005 | 08:07 AM
Fast John ll's Avatar
Fast John ll
I just got an "82 250 with 300" 6 and granny 4-speed with a 4.10 rear end. I want to put in an overdrive transmission. Which would be the best choice? I carry heavy loads ocasionally but I am not hard on my trucks-if anything I baby them. From reading other posts, I am aware of 4-speeds with OD that most people say are junk, also two different 5-speeds with OD. If these transmissions are out of the truck, how do I identify each one? Has anyone made up a list of manual transmissions available and a way to identify them-also what years they were available? Will I need to change the bellhousing if I change to a different trans.? Do the newer 5-speeds have a hydraulic clutch and if so how hard is that to hook up? Thank you.
Old Feb 10, 2005 | 05:13 PM
Dungeon_Master's Avatar
Dungeon_Master
heres a site that shows ford truck trannies http://www.motivegear.com/tech_info/...nny_guide.html
mmb617
Jan 9, 2015 12:11 PM
Necromancer
May 19, 2014 04:04 PM
niner
21
Nov 27, 2012 05:26 PM
JohnPeter
Apr 1, 2009 11:06 PM
willowbilly3
37
Feb 6, 2004 03:06 PM
