Best leveling kit
Old Feb 9, 2005 | 10:44 PM
bprox24's Avatar
bprox24
Best leveling kit
I have a 2005 f150 supercrew lariat about to arrive and am deciding on what would be the best leveling kit to put on. I really want to keep the best ride possible. daystar or Truxx????
Old Feb 9, 2005 | 11:08 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
...MOVED...
Old Feb 10, 2005 | 10:03 AM
BlkButy's Avatar
BlkButy
I went with the Daystar 2.5 Leveling Kit and I have had ZERO problems in the 14+ Months that it has been installed.
Old Feb 10, 2005 | 10:08 AM
easterisland's Avatar
easterisland
I have the skyjacker 2.5" spacer on my truck. I do not know if it is the "best" available yet or not...
Click picture for pictures of the install
Old Feb 10, 2005 | 10:11 PM
Blue Blooded's Avatar
Blue Blooded
I installed Autospring 2" kit(rear is 1" higher than front) and love it. Also easy to install(no spring compressor needed).
Old Feb 10, 2005 | 11:06 PM
Carguy1959's Avatar
Carguy1959
I installed a Autospring 2" as well. Took about 2hrs. Had toe adjusted 11/16 of an inch. Rides like new.....
Old Feb 10, 2005 | 11:18 PM
Bikeitswift's Avatar
Bikeitswift
Would a kit level this out??
Would a leveling kit cure this situation???
Old Feb 10, 2005 | 11:22 PM
Toreador's Avatar
Toreador
lol. No but a salvage yard might.
Old Feb 11, 2005 | 09:02 AM
trackdog's Avatar
trackdog
Best Leveling Kit
I went with the SkyJacker 2.5 Leveling Kit. Had it installed on Manday of this week, and so far, I love it....
Old Feb 11, 2005 | 06:09 PM
98Cobra's Avatar
98Cobra
That is one funny picture!
Oh yeah, go with Autospring!
Old Feb 11, 2005 | 06:53 PM
tpetty's Avatar
tpetty
I think everyone will say that the kit they installed is the "best." I went with the 2" Autospring (about $100) and love it. It's pure steel - no plastic parts to wear out.
Old Feb 11, 2005 | 07:27 PM
grayflare's Avatar
grayflare
A level kit is just a spacer that goes between the spring assembly and the upper a-arm. Since it doesnt change the spring rate or the shock or anything else that would affect the ride you can buy any one you like. They are all good if its built by a reputable company. I have installed a Daystar and the ride didnt change at all as with most other opinions of all types installed by the fine folks on this site. I would stay away from anything taller than 2 1/2" though unless you are buying a complete suspension lift. Just my .02.
