rearend
Old Feb 8, 2005 | 09:10 PM
ryanfire12's Avatar
ryanfire12
rearend
can i put a 1985 bronco 9''rearend in place of my stock 1966 f100 9'' rear?
Old Feb 8, 2005 | 10:26 PM
cdherman's Avatar
cdherman
U can swap 9" rears often, but I doubt that will work. Need to check out the spline count on the axels.. Your 66 will highly likely have a 28 and I tink de broco have a 31, at least in 85!!
Someone correct me if I am wrong.
Old Feb 8, 2005 | 11:38 PM
Putt's Avatar
Putt
Are you talking the whole axle assembly or just the carrier assy(pumpkin) or the axle shafts?
Carriers will swap as long as spline count is the same.
Complete axles will need modification to fit(length, spring perches, etc.).
Axle shafts will need shortened(I think) to fit the '66 and also spline count must match.
Old Feb 9, 2005 | 04:02 AM
jowilker's Avatar
jowilker
Short answer is no.
Long answer is yes you can swap the complete rear in with mods. Hangers will have to be moved, springs will have to be delt with. You will need the power disc brake upgrade, driveshaft connections may be different, etc.
John
Old Feb 9, 2005 | 05:41 PM
truckfarmer's Avatar
truckfarmer
The Bronco should have 31 spline axles and your truck should have 28 splines. The entire assembly will be considerably wider than your classic.
triple d
Jul 21, 2006 04:26 PM
rmalottwtes30
Mar 1, 2006 08:50 PM
Neppy
May 17, 2002 09:19 AM
otto
Mar 2, 2002 06:05 AM
AlM
1978 - 1996 Big Bronco
Oct 30, 2001 07:33 PM
